Help for long time existing customer but new to forums
I believe (i dont even meet requirements, so cant be sure) it's supposed to appear at the top within the graphics card subforum, similar to how the careers one appears at the top when within General
Just to confirm, you looked according to the location listed by Gibbo correct? As listed in post https://forums.overclockers.co.uk/posts/34874350
If so, make a post declaring you can't see it. Help them track the source of the prob so they can get it sorted for everyone. :)
I looked at the thread you posted and don't see any member deal thread? Or does Gibbo take it down after deal is done?
It highlights where to look for the sub-forum that's within the GPU forum section. If you can't see it however, then you're amongst the lot that can't see it due to a bug and that bug hasn't been tracked down yet. So posting here should alert someone that they can add your account into the mix that's having issue seeing it and hopefully that'll help track down the issue so it can be sorted for all elligible members.
The thread and subforum are both still up (although the thread is closed now), i'll add you to the list of users that can't see it.
I can't see the new sub forum either and I think I meet the entry requirements as I'm coming up on my 20th anniversary not being here and have 1500 posts
I can see the section, been around years, reading & learning, helping where I can. Fairly sure my account made the transition from the old forum.... Still working on gaining access to the MM...., this rate about 2040 :)
Looked again and still can't see it.
