Doesn't it? My 55 E6 does. I'll take a look at the 48 then. CheersIt doesn't have a glossy screen.
How is it with the glossy screen? It's the only thing I'm nervous about. I generally dislike glossy screens for monitors.
Now that gpu's have gone up in price, I have started recommending oled to my friends as a serious alternative to a new high tier gpu (they are mainly on 10 series and would usually go xx80).
Iirc Gsync is only supported on OLED on 2000-series and higher (but you might want to check that), just in case they expect it out of the box.
That's the only issue I have with mine, am in a bright room and it's beginning to drive me a little nuts! Only bad thing, other than being off and on my system all day so I'm having to manually turn it on every time
I would advise you to be cautious if you're sensitive to glossy like me...
does this come with the HDMI cable?
is it compatible with my rtx 3080?
You need to buy the cable separately.
I need a HDMI 2.1 cable then?
I see lots online, HDMI 4K and HDMI 8K, so confusing
Decent HDMI cable should do the job, the monitor is 40GBs bandwidth so get something labeled as that or 48Gbps.
For settings etc I found this reddit post very useful when I first got mine: https://www.reddit.com/r/OLED_Gaming/comments/ixhy39/lg_cx_gamingpc_monitor_recommended_settings/
I grabbed a 8-10k 48gbps cable today so cheers for that and I’ll take a look at the settings page
You don't need an 8/10k cable, the LG CX OLED 48/55 is only 4k and there no point having a 48gbps cable because the TV can only support 40gbps @4K, 120hz unless you're going into an 8K OLED @60hz So what's the point of an 10K cable?
Very tempting indeed but I may hold out until late rin the year like Black Friday to see any further discounts.Now with £100 off at Richer Sounds!
It may be overkill but it’s the best one I could get today whilst I was out that was above 27gbps so I picked it up I’m sure it’ll work ok but yes a lower end one would have been more practical
