Yeah just need 90 degrees to the left now.Thank you. Got it working now and edited the original post.
Most of us overclockers are using MPT to get some extra performance. When benching I run 425W on the PL and 400A on the TDC in MPT.
So I take it you have played with the settings a lot more since you did https://forums.overclockers.co.uk/posts/34438292
think I will have a tinker when I get chance.
Yes, things have changed since then.So I take it you have played with the settings a lot more since you did https://forums.overclockers.co.uk/posts/34438292
Furry muff. Gonna try your luck with another one?Decided to return that Ultimate with the adhesive on the Memory.
Its not somthing I've seen on any other 6900 XT I've seen.
WHat are you looking to do, overclock to the gills or just extend power limits a little for a 24/7 gaming overclock?
Damn straight it's worth enabling. Improves scores in most games from testing. Some games a few % improvement, some 10% or more.Is sam (smart access memory) worth enabling? Will it increase temps or would it affect an overclock or undervolt stability?
I used this for my Timespy score.I was going to go for a better result in Timespy and then look at a undervolt gaming profile.
I would use BIOS 3003, for me it has the highest boost frequencies for Ryzen 5000 series CPUs and the lowest Aida64 latency. Using a Crosshair VIII Hero myself and 3003.Ok, would you recommend updating my bios before enabling or because everything works fine atm just skip it and enable sam.
Fixed.Yeah just need 90 degrees to the left now.![]()
It seems Division 2 demo is available for a try. I tested it with my stable OC without any issues.If you have The Division 2 then run any overclock in that for a couple of hours, it's utterly the harshest game I know for overclocks.
Literally can not barely do ANY tweaking to my 6800XT Nitro in that game![]()
Did you manage to try out Resident Evil Village yet? I found that draws a lot of wattage at max settings. Not saying it is the most strenuous thing out there though.It seems Division 2 demo is available for a try. I tested it with my stable OC without any issues.
Is the XTXH a different PCB or is it just different BIOS? has anybody tried flashing a standard 6900XT with an Ultimate BIOS?I would pay a bit more for the XTXH version of the 6900 XT If i was doing it all again as it is definitely faster than the regular 6900 XT due to the higher voltage and power limits available.
Yes doesn't work.Is the XTXH a different PCB or is it just different BIOS? has anybody tried flashing a standard 6900XT with an Ultimate BIOS?
Yes doesn't work.
XTXH is the best silicon quality 6900 XT, faster than regular 6900 XT. 200Mhz higher boost clocks, faster memory, 1.2v voltage available and higher power limits.
The true competitor to the 3090.
Good question, think it is. Also it might be the MBA 6900 XT LC that has the faster memory and higher memory speeds, but the rest is definitely correct.Is it still limited/locked to 2150mhz though?
Oh, well if it goes above 2150Mhz then I guess I was right initially. You need to validate that performance is increasing though despite the clock going higher. I see gains up to 2124 on the regular XTX. Anything higher hurts performance.I have an XTXH - I can test. What would I see if I push it to 2250mhz and it was actually locked? When I click auto mm overclock it actually comes back as 2250mhz.
