The Radeon RX 6900/6950 XT Owners Thread.
So I take it you have played with the settings a lot more since you did https://forums.overclockers.co.uk/posts/34438292
think I will have a tinker when I get chance.
Yes, things have changed since then.
WHat are you looking to do, overclock to the gills or just extend power limits a little for a 24/7 gaming overclock?
Decided to return that Ultimate with the adhesive on the Memory.
Its not somthing I've seen on any other 6900 XT I've seen.
Furry muff. Gonna try your luck with another one?
Is sam (smart access memory) worth enabling? Will it increase temps or would it affect an overclock or undervolt stability?
I was going to go for a better result in Timespy and then look at a undervolt gaming profile.
Damn straight it's worth enabling. Improves scores in most games from testing. Some games a few % improvement, some 10% or more.
Ok, would you recommend updating my bios before enabling or because everything works fine atm just skip it and enable sam.
I used this for my Timespy score.
AMD Radeon RX 6900 XT video card benchmark result - AMD Ryzen 9 5950X,ASUSTeK COMPUTER INC. ROG CROSSHAIR VIII HERO (3dmark.com)
For undervolt just click Delete SPPT in MPT and restart, then undervolt in Radeon Software.
Start out at 2479 max frequency and 2379 min frequency. Set voltage to 1100mv, and reduce in 10mv increments until you hit stability in extended testing. I got my sample down to 1040mv before i started getting stability issues.
Seen others get around 1075mv+, so your mileage will vary.
I would use BIOS 3003, for me it has the highest boost frequencies for Ryzen 5000 series CPUs and the lowest Aida64 latency. Using a Crosshair VIII Hero myself and 3003.
ROG Crosshair VIII Formula | ROG Crosshair | Gaming Motherboards|ROG - Republic of Gamers|ROG United Kingdom (asus.com)
Use that BIOS, enable SAM, tune your memory frequency/timings, enable PBO, set scalar to x10, set PBO limits to manual and put 500, 500 and 500.
Optional but very time consuming, enable curve optimiser and fine tune each core using negative offset voltage one by one to squeeze out the last 5% from the CPU performance.
Can dig you out a video to get you started on curve optimiser if required?
I would pay a bit more for the XTXH version of the 6900 XT If i was doing it all again as it is definitely faster than the regular 6900 XT due to the higher voltage and power limits available.
Is the XTXH a different PCB or is it just different BIOS? has anybody tried flashing a standard 6900XT with an Ultimate BIOS?
Yes doesn't work.
XTXH is the best silicon quality 6900 XT, faster than regular 6900 XT. 200Mhz higher boost clocks, faster memory, 1.2v voltage available and higher power limits.
The true competitor to the 3090.
Yes doesn't work.
Is it still limited/locked to 2150mhz though?
Good question, think it is. Also it might be the MBA 6900 XT LC that has the faster memory and higher memory speeds, but the rest is definitely correct.
I have an XTXH - I can test. What would I see if I push it to 2250mhz and it was actually locked? When I click auto mm overclock it actually comes back as 2250mhz.
Oh, well if it goes above 2150Mhz then I guess I was right initially. You need to validate that performance is increasing though despite the clock going higher. I see gains up to 2124 on the regular XTX. Anything higher hurts performance.
ah, tried 2250 and 2200 and I get classic mem artifacting, so I guess that answers that question!
