- 6 Jan 2013
- Rollergirl
Why do all this? This is to stop the GPU from dying while mining. Never buy a mining gpu.
First of all, thanks for confirming that it's not just the 3090 affected as you claimed in post #2515. Secondly, as I pointed out to you yesterday the 3080 that I have hits the same temperature while gaming as it does when mining. I have no intention of changing thermal pads because it's operating within specification and if there's any issues then I'll RMA the card just like anyone else would.
You ask why people change pads, then you answer your own question with more BS. They don't change the pads to prevent the card from dying, they change the pads because the card will throttle as it's designed to do regardless of mining or gaming, and when it throttle it makes less money. They risk the RMA process to make more cash, simple as that.
Your blanket statement about not buying a card used for mining is totally misplaced, not least because there are people who game with the cards and have changed the pads to improve temperature not for financial gain but for performance gain.
Pushing hardware to it's limits for gains isn't new, that's why we have water cooling kit for sale. You need to do your research properly and stop hunting for articles that support your confirmation bias.
