played some more last night on the 3090FE and yeah something is off with the draw. I'll try 30fps cap tonight to see if it still wants to draw crazy amounts.
I've got a hell of a lot of airflow in my rig so it's not getting hot but it does have me worried. Think i best see what the Vram temps are getting to.
I've narrowed it down to the main menu. I never actually got into a server last night due to queues etc but this morning I got in straight away, so I moved the fps cap back to 60 and the power draw seemed ok (233W / 1v) for the ~50% utilization
In the menu the utilization goes up (probably because of the background) and at the same 60fps, the usage is 266W / 1.1v.
This causes the GPU usage to spike up a little, the core to get hotter and the fans needing to do more. I imagine people queueing for hours with the extra juice are effectively mining and in rigs not set up for the constantly higher GPU power draw.
The easiest fix would be when you go to log into a server, a static picture becomes the background (with a low fps lock like 10), with the queue in front of that.
