What "man jobs" have you done today?
dod
dod
31 Oct 2002
Inverness
Got a few days off to catch up with stuff. painted an external retaining wall, laid new floor in spare bedroom, got digger in to prep a bit for a new patio, cut grass (again :mad:)
9 Mar 2012
West Sussex, England
Finally finished my nest doorbell (wired) install. Was giving me the run around as there appears to be a bug in the software with mechanical chimes. Had to switch on chime duration even though that is intended for electronic chimes but once that had been cycled through on and back to off it now works as expected.
19 Dec 2017
Little bit late, but fitted a nice new garage door!
It makes such a big difference to the insulation of the garage, which is useful when its attached to the house.
Before:
After:
9 Mar 2003
I’m not a fan of the colour (white would have been my choice there) but I have zero regrets about our motorised door, it’s great and I’d never go back. I don’t really understand why manual doors are so popular, looking across ‘the pond’ they are basically ubiquitous.
Getting one that is insulated makes so much sense when it’s integrated into the house.
19 Dec 2017
I get the thoughts on the colour, I always imagined it was a given that it'd be white until I was given the choice when ordering it. I just liked the idea of having it a bit different in the end, although I'm not about to go replacing all my PVC with anthracite any time soon :o
I think it's a mixture of a lot of detached garages without power and money. Lots of cheap up and over doors are sold without operators but you'll be hard pressed to find a manually operated sectional or roller door.
9 Mar 2012
No need to replace the door you can have them resprayed.
20 May 2007
Cut the grass, tidy up in the garage, tip run, drop off at the charity shop
Then spare / broken garden furniture transformed into kindling
Put a bottle opener in the garage
And put up a temporary "sail" over the patio until the gazebo is installed
28 Dec 2017
Beds
@{SAS}TB I so enjoy watching your house come along :)
Yesterday/today I've trimmed two weather/drip bars and a new stile for the garden and roof doors. Fitted, primed, first coat of gloss. I'm really bored of doing full cleanup after using green oil based paint. 10 minutes of painting followed by just as much time cleaning brushes and hands! Last coat tomorrow and I can put everything away for a bit.
20 May 2007
No comparison a £12 bit of material against a £3-4k gazebo but gives a bit of shade / shelter for the Mrs going gardening shizzle outside
Seems sturdy enough and will do its job (also store some garden furniture under there as well) until the gazebo is ordered / installed
27 Mar 2013
OK fair enough. The gazebos I've been looking at wernt quite that much, more like 3-400.
