@rob77 I met over on ispreview forum.
@Firegod I come to share my experience here too.
My situation is: I live in an area where the broadband speeds I can get is 10mb DL and 2mb UL. So I needed to find an alternative internet option.
For the last 16 months I have been using a mobile broadband connection on an unlimited data plan with EE. Recently moved over to 5G speeds from 4G-LTE-A
I was using a Huawei B818 for my 4G connection and speeds were decent. No external aerial used and speeds on hard wire was around 250Mb DL & 10Mb UL. A considerable difference from with conventional BB can offer down the copper line.
I used this device and connection for just over a year and was perfect for my needs.
Since 5G became available, I upgraded to the Huawei CEP Pro 2 Modem. No external aerial option but I was hitting pretty decent speeds. 400+Mb which I was very happy with.
I found that this modem was dropping connection a couple of times and sometimes froze (requiring a reboot), Had WiFi connection but not internet at the end....
I was looking for a more stable modem so I ordered the Zyxel NR5101. It arrived and I was very disappointed with the speeds.
With the internal antenna's I was getting a connection of about 72dbs so in the Excellent range and was hitting no more than 100Mb DL.
I purchased the Poynting 5G external 4x4 MIMO antenna but it made zero difference.
I am now going to stick with the Huawei CE Pro 2 as it out performs anything I have tried. Signal is around 65dbs with the internal antennas.
I do have circa ~100 devices connected to my home network and the CE Pro 2 struggled to handle the DHCP and continuous connections for all devices so I had to make some changes to the network setup.
This is the setup I have now and I will stick with it.
Huawei CE Pro 2 - Running 5G connection (Bridge Mode)
DrayTek Vigor 2927 - Used as the router providing DHCP
Ubiquity AC Pro x2 - These are the Access Points I use to connect via WiFi.
The Huawei is doing very little work, simply providing the internet and since using the DrayTek to handle all the connections, the Huawei has performed considerably better than before with little to no drop outs.
The DrayTek 2927 is a fabulous router and can handle dual WLAN so you can connect up your Mobile Route and home broadband to combine speeds if you need more.
Ubiquity AP's are solid and monitoring them using the cloud platform helps with device connections and statistics.
Speeds:
Hard wired connections to my MacBooks are seeing 650Mbps DL and 40Mbps UL
Wifi on 5Ghz is approx 550Mbps on the same Mac and 20Mbps UL
Wifi on 2.4ghz is approx 200Mbps on the same Mac and 15Mbps UL
I Hope this helps those of you reading. If you have any questions, im no network expert but I can advise on what I have learnt.
