Did you buy a hard board over there in the end?
Yeah. Naish Glide 12x30
I'm after some advice on purchasing my first iSUP. I'm 5'8", 79kg. I need a board that can carry a dog (23kg), maybe some gear, maybe share with a child instead. So I'm thinking something longer and wider. I image it'll be used mostly on lakes, but I do live near the beach (Liverpool) so if it can handle some mild surf all the better. And maybe canals.
I already have a wetsuit, buoyancy aid, gloves and boots. I'll be getting a BA for the dog.
I'm happy to spend a little more to start with as I don't like to buy twice (buy cheap) but a Red board is too much. From what I've read the cheaper boards are mostly single layer anyway, so probably not suitable for a dog.
I've sort of narrowed it down to the irocker all round 11 at £782 with kayak extra and free elec pump or the Bluefin Cruise 12 at £650, which includes the kayak seat, but no elec pump.
I'm leaning towards the bluefin for its 5 year warranty.
I'd be interested to hear your thoughts on those boards, or suggestions for others.
Thanks for recommendation.
I've decided to go for the Bluefin due to a recent voucher offered by Amazon. The board was already cheaper than the manufacturers website at £650. But there was an additional 5% off voucher and I had £150 in amazon vouchers. So all in it cost me £466.
Fingers crossed my board is made better. I'll be thoroughly checking it.
So what's the scoop with a licence to use waterways? A mate in work says I should get a British Canoe Club membership as it provides it. Although it's only £45pa, for a family of five it'll cost over £130pa!
I think that is the cheapest way to do it if I’m honest. Have you each got a board?
Not yet. But ultimately I want this to be a family affair.
I'll just have to start out with one for me.
This is my boat, more a river boat but still OK on still water.
Is that a Liquid Logic Hoss?
Water Skills Academy is slightly cheaper at £30pa. It misses some licenses down south though so you’d need to check your local options.
1) my fix on the Gladiator has worked. Fin stayed in!
2) touring fin helps massively with tracking and speed.
Didn't the gladiator come with a touring fin anyway?
Been out a lot on our boards since buying them. Once my son went back to school the mrs came and gave it a try too. Might end up needing a 3rd board!
After a few times in a week pumping up two boards in the heat I've had enough. Got the HIKs 20psi pump and for me it's a game changer. My son was just not heavy enough to pump past 8-10 psi. I'm now no longer knackered before I get on the river.
Nope, came with a dolphin fin shaped one.
I'm getting reasonable at going straight in very little wind with few paddle side changes. But going into wind I struggle to the point that sometimes I'm just twice as quick to kneel. Is this normal?
