Intel Core i9-12900K allegedly scores 30K points in Cinebench R23
14 Nov 2005
Further news - crazy single core performance also, expanding Intel's out of the box performance lead in Cinebench R23.
https://videocardz.com/newz/intel-c...g-4-spotted-2k-points-in-cinebench-r23-teased
It's rather interesting to observe how AMD fans no longer care about cinebench scores, when previously (when Ryzen was chart topping cinebench) it was one of the most important metrics.
That's not news. Intel competing against a chip 12 months old. Have you not learnt your lesson yet, wait until all the official reviews are out before banging your drum, last year you looked more than a little foolish after posting all those new threads about the 11000 series only for most of it to be tripe
Permabanned
2 Sep 2017
Competing against what's available. It's just silly to mention that the chip was 12-month old, even there is nothing new coming from AMD in the near future.
14 Nov 2005
There are new chips coming from AMD though, Leaks suggest updated ZEN 3 parts with 3D cache later this year possibly December, so yeah it is relevant plus what we are seeing is Intel at least 1 year behind AMD. What i really want to see though is a 8 Zen 3 cores clocked at 4Ghz against 8 Alderlake cores clocked at 4Ghz. Both systems running Mem at 3200 and a third running DDR5. I want to see the IPC difference in those scenarios, which architecture is better Intel or AMD's and ho much effect does DDR5 have. While we are about it lets do these tests in both Windows 10 and windows 11
28 May 2007
Near future as in the next few days?
AMD’s 3D V-Cache updated could be here before Intel’s new chips. Milan-X and Threadripper too.
Permabanned
2 Sep 2017
Neither of which is an ordinary desktop mainstream chip which is what I meant.
I thought everything by AMD was cancelled, next is Zen 4 by end of 2022.
26 Aug 2004
South Wales
Assuming the early boards will be limited to Alder and Raptor, does that mean if wanting to buy when Raptorlake comes around it will only allow that chip and no upgrade to Meteorlake?
I'll be going 64gb DDR5 when the speeds and prices get more decent :) maybe either 2022 or 2023.
14 Nov 2005
Milan X should be very soon. Looking at that it has 32Mb L3 Cache plus 64MB stacked L3 cache per CCD so i am guessing we could see a 5950X refresh with a combined total of 192MB L3 Chace??? Plus with teh node improvemnets a subtle clock increase. It is going to be very interesting. I reckon AMD will only do this for Desktop chips if Intel push the current line hard enough
28 May 2007
768mb of Cache on Milan X.
14 Nov 2005
You need to expand your horizon away from WCFTECH. This article came out before Lisa Su announced at Computex in June 3E V Cache on a 5900X, from there it was leaked we would be seeing those this year. for reference also Rembrandt which is AMD next APU line is already in mass production and is part of the 6000 series. If Alderlake is as good as you and Dave hope then there is no way the 6000 ZEN 3 would not be launched
7 Dec 2015
Intel Core i9-12900K allegedly scores 27% higher than Ryzen 9 5950X in CPU-Z single-thread benchmark
This strong single-core/thread performance appears to be mirrored in the CPU-Z test, which has supposedly been leaked on Bilibili. The CPU scored 825 points, which is 27% higher than AMD Ryzen 9 5950X. While the CPU was not named, we can clearly see that it has 24 threads, which just happens to be the configuration of Core i9-12900K (16C/24T).
With 825 points, the CPU would outclass all CPUs in the official ranking, with nearly 20% higher performance over Rocket Lake-S i9-11900K. The multi-thread performance has been blurred out, but we can see that the blue bar matches the width of the purple bar (5950X), which suggests that both CPUs should have identical performance.
28 May 2007
Multi thread is probably somewhere between 5600X - 5900X. The Atom cores at 3.7ghz are supposedly around desktop Haswell performance.
27 Apr 2007
Has anything changed since this from June?
https://www.anandtech.com/show/1672...acked-vcache-technology-2-tbsec-for-15-gaming
Update: June 1st:
In a call with AMD, we have confirmed the following:
"This technology will be productized with 7nm Zen 3-based Ryzen processors. Nothing was said about EPYC.
Those processors will start production at the end of the year. No comment on availability, although Q1 2022 would fit into AMD's regular cadence."
With this working with the AM4 platform it gives AMD a lot of flexibility.
No need to rush AM5 when you can give AM4 a decent boost and rain on Intel's parade.
Plus it doesn't need W11 to get the most from it, which will really appeal to some.
14 Nov 2005
Update: June 1st:
I have seen reports saying the desktop chips will be out around December, it will ultimately depend on how good Alderlake really is
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Caporegime
17 Mar 2012
It does unless your adding an offset the boost or messing with PBO/curve optimizer.
Yes, my 5800X is effectively running like a 5900X in ST (5.0Ghz) its in my signature. It runs at that speed in games too. a hard load is 4.7Ghz.
Also, plebeian 3200Mhz RAM, 16-18-18-18-52 (2X 16GB)
Its not the best showing for a curve optimised 5800X.
