Have a read of this >> https://www.reddit.com/r/AMDHelp/comments/eyo0qc/need_help_with_random_shutdowns_on_my_ryzen_3900x/New PSU didn't fix the issue. :'(
I'll give the CPU a low overclock to test.
Can someone give me some basic options to choose, so I don't over-do, under-do it please?
I'd rather put in a community-validated overclock rather than just something I thought was 'ok'.
Thanks in advance!
Thanks mate. Happy to set it to that and test. How do I actually do that on my board?something like 4ghz all core with 1.3v
That's all you have to set, multi to 40 and vcore to 1.3 although I'd probably go for a 44 multi which should give you 4.4ghz which just about any 5800X should be able to do, it will be the high boost low load scenario where it's failing so setting an all core lower than the single core boost of 4.7/4.8 should enable you to confirm if it's the CPU that's faulty which is most often the case in these situations.Thanks mate. Happy to set it to that and test. How do I actually do that on my board?
I assume it's not anything to do with PBO and curve optimization.
Back in the early days of intel overclocking, it was all ever-so-simple, the only overclocking options were multiplier and vcore. Long gone are those days![]()
MSI.
With the above settings, it still hung this morning after just over an hour of idle.
This is really weird.... i would be tempted to RMA the CPU but if you do that and put the replacement in you may end up with the same problem, in which case @jigger has been trying to tell us something for a few pages now....
MSI.
I guess the motherboard is over 30-days since you bought it? If it isn't, you should be able to claim a full refund inc shipping costs, or request a repair/replacement of the faulty product.Raised a return with where I bought it from. They'll be sending it back to manufacturer for me apparently.
