- 14 Aug 2018
I had a quick look through the graphics settings but can't find anything to enable/disable it so guess it's enabled by default if you've downloaded it. I did get warned that my drivers are out of date, as it's been a couple months since I last updated them, so I'd better get the latest ones.I have downloaded it but do I need to enable it or something in the settings?
I'm just playing with the built in benchmark and playing around with the settings but so far it is running at good frame rates on high, even ultra.
