**** Please enable 2FA on your OcUK forum account ****
Edit: I’ve just seen your own edit. No bother. Whether it’s hosted with BW, me or the pope doesn’t matter. Back up your vault weekly or monthly, use a strong master password and you’re set. The offer was to less techy members, I’d imagine most of us can run a server and use GPG and AES crypt.
The standard user ain't going to do that. That's one of the problems even with a password vault. I have my server data back up twice a day automatically as well but once a month I do export my vault to a private store sitting beside me.
Yeah that works when you are happy to keep cookies for ages. I use private browsing and clear out cookies when I close a window. Sure I could leave it open, but habits.
In modern browsers you can select favourite websites to preserve?
CookieAutoDelete and whitelist your trusted sites. It's somewhat redundant in Firefox, especially with Fission enabled, as every individual site now gets its own cookie jar. That way, no cross-site tracking from third parties is possible. Plus you have the option for container tabs and such.
Thanks for the replies and some great advice in this thread, the very few sites I use I have different account names and passwords its why I can remember them all. :D
I dont use 2FA as nothing I use requires it but I'll look into it as it seem its becoming more and more commmon place to require it.
I have an old phone that could be used though even with my payg phone I get messsages every now and again to it saying the number could be removed if I dont put credit on it for ages, I dont wnat to set up a phone/SIM and it get removed. :confused:
I just came on to the forum and OCUK had logged me out asking me to input a security code via phone app! Did someone try to access my account or was this just a security check up?
This is normal, every so often I will get the 2FA prompt when visiting the forum too. I just thought it was part of normal "confirmation that it is me. If it was
someone trying to get in, you'd get an email saying failed login attempt/forgot sign in process etc.
That's Pay&Go for you though, most networks will remove your account if it's idle too long. You could get a £6 a month monthly SIM only contract though, maybe even cheaper than that these days.
Edit*
£5 a month with 1GB data, sorted: https://mobile.asda.com/bundles/standard?bundle=BUN5
Just done mine - should have done it already considering I'm a security consultant tbh :p
All my more important things I've used 2fa for years though
I've always enabled 2FA, however I've never done the QR code thing before! Which I now have on all my other accounts that I know of :D
I just tried to do 2ga via email and my account is linked to my uni email that i havent had access to in over ten years, i did do manage to authenticate via the google app.
How can i change my email please?
You should be able to go into your account and change your email address first. Then when that’s done, enable 2FA. If you have problems, start a thread in FCD and we’ll do it for you.
If you've got 2fA enabled it lasts for 30 days on a device if you tell it to remember you, then will ask you to enter a new code once the old one expires.
