- 26 Sep 2013
- West End, Southampton
only the poors version on GP and you have to wait to play it![]()
It's day 1 on gamepass I thought.
earlier if you have premium or pass, November 5thIt's day 1 on gamepass I thought.
Why wouldn't you just get Game Pass?
I have everything else I want off game pass.
I've played 700 hours of FH4 over the last three years. Game pass would have been much more expensive.
The premium add ons FOMO stuff is 40 quid on top of the game pass version.
The Steam FOMO edition is 80 quid.
I'd smear myself with honey and run naked through barbed wire while being pursued by Afrikanised Bees to avoid the MS store. Actually I'd do that for defacations and giggles, but that's just me.
The MS store defies physix by sucking and blowing at the same time.
The rumble on the xbox controller triggers didn't work on FH4 steam, they've said it's fixed for 5. I've heard that Steam was even more sketchy than the already sketchy windows store version for connecting to multiplayer but haven't tried it. If you buy on Steam it's 5 quid cheaper but you don't get to also play it on your xbox if you have one.
That said I've preordered FH5 on steam because the windows store is an abomination. Badly laid out, hard to see what you need to install out of multiple pointless options and about half the download speed for me.
Only £64 on shopto for Premium version !! Windows Store and Xbox
I'm pre-ordering as it looks boss !
It's only £24 odd on top![]()
Can't make the numbers add up.
But then the only numbers I really understand are horsepower.![]()
I think I'll grab it on Microsoft Store - despite everything you mention above, I'm certainly not disputing any issues as I always had problems with updates mainly on WS.
premium edition £52.47
premium add-on £23.74
Buy using fee-free card for those prices from the Icelandic store (see HUKD for details)
Just to confirm, if I get Xbox Game Pass, I'll be able to play from the 5th?earlier if you have premium or pass, November 5th![]()
9th unless you buy the premium add on
Thanks, yeah just checked and Standard unlocks on the 9th.9th unless you buy the premium add on
Is there a "best place" to buy the upgrade? I just subbed to Game Pass because of AoE IV and FH5 so FH5 standard will be free but is there a way to upgrade? Wouldn't mind playing from the 5th.This. I’ve bought the premium pass so I can play a few days before I go back to work!
Before downloading Forza Horizon 5, ensure you meet the storage capacity requirement for your platform of choice:
- Xbox Series X|S: 103 GB
- Xbox One: 116 GB
- Windows: 103 GB
- Steam*: 103 GB
Better compression technology on the other platforms?Weird that the XO version is 13GB bigger than all the others, the only explanation I can think of is maybe it needs to include some lower resolution assets that wouldn't be needed on XSX/XSS, and they also left the higher res assets in there.... but even then, you'd think the PC versions would have them also to cater for weaker PCs? Just seems odd.
