Raptor lake will be a drop in upgrade that will probably launch before or at a similar time to the Zen 3 refresh. Though Zen3 still stuck on DDR4 and PCI-Ev4....
Huh?
God knows what they are doing... I had max 92c when doing Blender render for hours on a CPU running 5.1ghz P and 4.0ghz E with 360mm AIO.100c for coolers not fully optimized for Alder Lake and mid 90s for those supported out of the box in hardware unboxed review![]()
See that sounds way more convincing to me than what Alder Lake had going around. Like you said it really shows how desperate it is when these cores run at over 90c on water! That's nuts!Its not that convincing is it?
The thing is looking at the boarder picture it seems Intel are having to go to ever more extremes to fight with AMD, these massive cores that are 3X the size of Zen 3 cores, the insane power consumption.
If all AMD did was Zen 3D with no other changes they would be back on top again.
Zen 4 is rumoured to have a 30 to 40% IPC advantage over Zen 3 and they will probably bump the core count up to 24 cores, rumours are they are working on a 16 core CCD, so it could be 32 cores with that IPC gain on mainstream.
ASUS Strix A very solid.......Tried that a lot....12600k with a cheapish ddr4 motherboard would be a good option.
Did you check your samples to see if the IHS on these chips are domed enough to cause an issue?God knows what they are doing... I had max 92c when doing Blender render for hours on a CPU running 5.1ghz P and 4.0ghz E with 360mm AIO.
lol.... so Intel's efficient architecture is working well.
Holly ####
Bad mount or setting.... possibly over agressive LLC...12900k gets to 100 degrees heat, with a corsair 360 AIO!!! holy moly!
I have had one concave which was a possible problem...Did you check your samples to see if the IHS on these chips are domed enough to cause an issue?
I agree. Think I am going to go for the 5900X+X570+Noctua NH-U12A. I think the heat generation is way too high for the performance. It simply can’t be cooled by any of Noctua’s air coolers and DDR5 pricing and motherboard pricing is just bonkers.Its not that convincing is it?
Would be good to see a sample size of how many have this issue and might explain some of the dodgy temps people are getting in reviews.I have had one concave which was a possible problem...
Now I'm really stuck on what to do...
My gut is telling me 5800x and a refresh chip next year.
Or go ahead with the 12600k and ddr4
It’s reaching 92 degrees in TPU testing. I don’t think any air cooler would work with it.Bad mount or setting.... possibly over agressive LLC...
Gamers Nexus used an Arctic Freezer II 360 for their 12900K review and noted it didn't exceed 80 degrees in Blender rendering. The Arctic cooler base covers the whole IHS on ADL though whereas the Corsair AIO does not.12900k gets to 100 degrees heat, with a corsair 360 AIO!!! holy moly!
Does it reach that when gaming?
It aint much faster than zen 3 at 1080p and who games at 1080p with a top GPU. Zen 3D cache edition should take the lead again. 12600K is the best alder CPU if paired with a cheap mobo and DDR4.
Nope only when doing work specific tasks like rendering etc.
