any idea why the 12900k on ocuk has jumped up £100? was the £550 before an introduction offer?
The OEM version is £559 currently so maybe that was the one you are thinking about ?any idea why the 12900k on ocuk has jumped up £100? was the £550 before an introduction offer?
, next week maybe the £100 more you state.
Problem solvedThat MSI cooler is an Asetek gen 7 pump afaik. You can buy the bracket from OC!
I still really don't understand why motherboards are shipping with PL1 set to 241w (or even inifinite) when it performs so well at the specified 125w. To top the 5950x in more benchmarks? Did Intel push motherboard manufacturers to do this?Can 12900k match the M1 Max in efficiency?
12900k tweaked for efficiency:
6 big cores locked to 3.0ghz
8 little cores locked to 2.4ghz
Maximum power limit: 35w
Cinebench R23: 14288 points
M1 Max 30w: 12326 points
the M1 max gets 410 points per watt and the 12900k gets 409 points per watt.
so mission accomplished, the 12900k is extremely efficient at low power limits and goes head to the head with the efficiency king, M1 max. The 12900k achieves 50% of its 241w performance at just 35w.
Wow, good work Intel. After so many years this is a really impressive bump. Makes the whole 11th gen fiasco look a bit daft, why bother when they knew what was around the corner?
Even the energy efficient is much improved, however, I'm still very happy with my 5600X and plan to keep it for several more years.
Do AMD have something competitive coming any time soon? Seems a tall order to overhaul Intel now like they did with Zen3.
You answered your own question!I still really don't understand why motherboards are shipping with PL1 set to 241w (or even inifinite) when it performs so well at the specified 125w. To top the 5950x in more benchmarks? Did Intel push motherboard manufacturers to do this?
Yeah, quite.You answered your own question!![]()
Noctua seems to be the only one who had their act together when it comes to brackets.
Agrred. What's especially amazing is the energy efficieny when gaming. You get the best gaming performance of any CPU to date, coupled with lower power consumption than Ryzen!
Source: https://wccftech.com/review/intel-c...-wifi-g-skill-trident-z5-ddr5-6000-memory/15/
Awesome thanks,I ordered two brackets all ready,I can wait.Also I have enermax liqmax iii 360 argb white with white case,I am going to sell the MSI 360mm.That MSI cooler is an Asetek gen 7 pump afaik. You can buy the bracket from OC!
It is weird,it is not like the Intel CPU snuck up on them with CPU coolers but they must be just clearing out stock.Noctua seems to be the only one who had their act together when it comes to brackets.
