Obviously peoples temps are all down to their enviroment, I am in a fairly warm room, not of lot of air flow about
This was the temps from playing control with all the bells and whistles on @ 4k leaving fans speeds at default settings. Could be mine was poorly built as the cooler just fell off once unscewed where as normally more effort is required to remove a cooler from a card.
After fitting the water block on a 20 loop timespy stress test it went down to the following with a +190 and +1000 OC
It should be noted the 5950 is in the loop at this point too and also I did not realize rads were clogged despite dust filters and my water temp got up to 55C at some point
as I run low fans speeds for noise reasons 1k max (not hit 55C during this test BTW, just observed whilst playing) I have since cleaned it all up and not seen higher than 42C temps on water so perhaps the numbers would be lower if I tested again, this was with the ~130quid Alphacool block, not the fancy pants EK one.
I will reset HWInfo and note some updated numbers on my next play session.
Cheers
