The problem is, having to yank the magnetic end out everytime i come to charge the headset via the Anker charging dock. Unless there's a cable thats compatible with the anker dock cos the one i have now (which is magnetic also, just too long) isn't compatible. The magnetic poles are the same so it doesn't attach lol.id get a magnetic one
You may have checked, but look at the postage options for Aliexpress, recently ordered a few things on there, and found that switching postage option could add only a £1 or so, but reduce delivery time by weeks.
I should update this thread with a new pic of my case how i keep it
Not the stock strap anymore, its the GOMVR from Ali Express, and has a anker power bank attached
I even tagged you in the thread!!
sorryThinking of replacing my MVH studios headstrap with something else. The Kiwi Design one looks good, and love the ability to raise the headset without taking off the strap.
However I don't like the fact that there is no counter weight. Or have the option to buy the same strap with an inbuilt battery.
Considering the Bobo M2 pro. Can only get them from Aliexpress though and if I order now, it won't arrive until the end of January
Am actually thinking about just buying the elite strap with battery. And then buy the Foam pad add on for the Elite strap from VR cover. I wish you could buy the Elite strap with battery without the bag.
EDIT: I am just after finding out that Oculus have introduced an Elite Strap with battery option that doesn't include the bag. So I might just get one of those instead.
I got my m2 pro from Amazon a few weeks back you checked on there?
I have the kiwi one and it's superb. So much better than the original.the best strap to get ?
