Dice as usual getting ready to nerf stuff - just as players get the unlocks and learn how to take things down easy.
Sounds like RPG life.
Got to the config file and ensure DX12 is enabled and anything that mentions raytracing in there is off.Same for me, I have to push the resolution up to something stupid just to get 90% gpu usage and even then I'm dropping below 60fps. On a 3090 :-|
Scoreboards are a legacy feature apparently
https://www.ea.com/games/battlefiel...eld-briefing-launch-update-and-the-road-ahead
I did this and all the stutters and hitches went. It's almost as if some of the main settings are broken.
It's like they throw everything away and start from scratch every time.
So i have this on my Series X and am thinking of getting on my PC too. How would it run on a 2700x, 16gb ram and a 1070?
I found that disabling DLSS in this title not only improved image quality (expectable) but also smoothened out gameplay by noticeably reducing stuttering. That's a first for me. I've always been fond of DLSS as an acceptable compromise to image quality to gain performance.
Cause dlss introduces cpu overhead and this game is purely cpu limited.
I was on Discord last night with 2 of my buddies, who have the game still. We were able to go into the PROFSAVE_profile, and tweak the sound settings. SoundSystemSize was set default to 20. We upped those to 128. And we set the GstAudio.Volume_SFX to 5.0. default was 1.0. At the default 1.0 setting, SFX were way to low/muffled sounding. Set to 5.0 this really help the ingame SFX sounds and weapon sounds immensely. As well, we turned off the Announcer Voice. Announcer Voice seems to mute ingame sounds every time the Idiot starts to talk. There really are issues with the ingame sounds that drasticly need to be worked out. Really hope they fix them. All they need to do is look at Modern Warfare 2019s ingame and Weap sounds. Then adjust 2042s accordingly.
Anyways, I decided to rebuy the game in light of the tweaks we did. Weap sounds are now decent enough with much better punch. Not perfect, but way better than stock for us. .
Jayz2cents did a youtube review last week and showed there was no difference in perfomance between DLSS off or on, so it's broken in this game
.Dice as usual getting ready to nerf stuff - just as players get the unlocks and learn how to take things down easy.
