Fasting. It's actually healthy for you too. That is the fastest and easiest method. I have fastest the longest time for with water and supplements only (vitamins and electrolytes) zero calories for 3 days then broke it on the fourth then fasted again for 3 straight days.
I have also fasted for 3 days on another occasion then started a vegetable juice diet for 2 more days to make it a liquid only fast for 5 days where no calories were consumed on the first 3 days.
To keep it off requires a long term change. There is no point in you getting the weight off going back to old habits and then putting it back on because people who do that tend to put more weight on than before they started. So you are going to end up fatter again if you don't make permanent changes to your diet and physical activity.
You can have a 6 pack through diet alone but a good diet coupled with a good physical routine will keep you healthy. This doesn't mean you need to do hours and hours per day. I'd say 30 mins of intense cardio is enough daily. If it's not intense then you want to do 1-2 hours daily.
That's the major problem. Most folk are sat behind desks 9-5. Sat behind the wheel of a car for an hour or two or on a train and then sat on a couch when home. Humans even as little as 100 years ago would walk for hours on end every day. They didn't have cars or public transport.
Wrong. Muscles weigh more than fat yes. But muscles also consume more energy than fat. So someone who has a large muscle mass consumes more calories by sitting still compared to someone the same weight with less muscle mass. There is a difference between fat loss and weight loss. Most people mean fat loss when they say weight loss.
Just because something doesn't work for you doesn't mean it's wrong or again dieting to lose weight is apparently for the lazy is what you said last time. Which was lolworthy and again you have a false idea of how muscle mass works to keep fat low.
https://www.t-nation.com/training/screw-cardio-four-complexes-for-a-shredded-physique
Used that link and did 2 of 4 of those (barbell and dumbbell), three sets each at the gym yesterday.
Feeling it now.
Will definitely be keeping them in though, thanks.
Those complexes routine IMO is the best form of exercise. Building strength, stability, core and cardio at the same time in a small time frame. It's an all round routine and perfect for anyone at any stage. You just use smaller or bigger weight. Start small though it's brutal cardio if done properly.
The idea of pedalling a bike for 4 hours per day isn't appealing and doesn't build majority of the core strength if any. I do like cycling and running but those do nothing for muscle mass or strength or your core other than posture.
CrossFit is based on the same concept but usually requires a lot more space and equipment.
One of the complexes just requires a weight plate for instance gripped at each end with both hands. That could be any size plate for any level. It's intensity is the focus not using the largest weight possible and going slow like traditional weight lifting.
Did the barbell set with en empty bar (20kg) for three sets. Then added two 5kg plates, but struggled to do shoulder press and only managed three reps. After that I just did the routine up to shoulder press and rested then one more part set.
The dumbbell routine I used two 10kgs and that was reasonably comfortable, so probably up it to 12kgs dumbbells next time and see how I go.
Never been a fan of traditional cardio, particularly at the gym on a treadmill or exercise bike. Plus at 52 years old, I believe, resistance training is far more beneficial to me than jogging or cycling.
Be careful with those type of scales as they are very commonly calibrated incorrectly. You can get on it after turning on and be 2kg heavier than if you wait a minute and then get on it again. Best thing to do is get a known weight and put it on it to see which is the correct calibration.
Yeah, scales aren't moving much but my clothes are a lot looser.Abandoned watching the scales for a change, lost the first 15ish lbs and then weight loss started crawling. Body composition is still improving massively weekly though.
Very niceThis is where I ended up btw, semi-relaxed front/back. Should probably have taken before pics.
Got leaner than this before but started out with more body fat than I’d had in quite some time so it’ll do. Next time I diet I won’t have let myself go so much so maybe I’ll see if I can look like a human road map again. Maintaining weight till December then I’ll start seeing if I can ‘fail’ at weight loss and let it creep back up again (this time with proper training, unlike during lockdown…).
