Very exciting times indeed
with Raptor lake at 24 cores, AMD shall n be d to push to higher count as well, less they lose the multi thread performance crown to Intel
That would only allow for 5 watts per core. I think AMD would still be ahead.
you're ignoring that e cores don't use or need the same power as p cores and that Raptor lake features new power management allowing it run to 20% lower voltages
https://videocardz.com/newz/intel-r...egulator-dlvr-could-reduce-cpu-power-up-to-25
Does anyone else think 'Raptor Lake' might actually be a HEDT counterpart to Alder Lake CPUs, with the same 'Golden Cove' cores?
We know the Sapphire Rapids server CPUs are due for mid 2022, equipped with the same 'Golden Cove' core architecture as Alder Lake /12th gen CPUs.
In terms of the HEDT market, you'd thought a new product was long overdue, and the 10nm yields are finally looking 'good'.
lol, don't act so pained and grow a pair, it's just tech.
Nobody has blown anything out of proportion. Raptor Lake is rumoured to be nothing more than a tweak to Golden Cove on the P Cores and doubling the number of unmodified Gracemont E cores. That's it. No new arch. If anybody's "blown it out of proportion" it's Intel because that alleged Golden Cove upgrade is called Raptor Cove. Good old Intel claiming everything is new, just like Skylake and its 4 derivatives. Raptor Cove is a new arch to Golden Cove in as much as Kaby Lake, Coffee Lake, Coffee Lake Refresh and Comet Lake are a new arch to Skylake.I think rumours have blown it out of proportion, or likely misrepresented what it is.
Unless you consider the additional rumour that Golden Cove is not Golden Cove across the board. Server Golden Cove (and by extension the HEDT line) is suggested to be quite different to desktop Golden Cove. AMD are doing the same thing with Zen 4 and Zen 4C don't forget.It makes no sense to design a new core architecture, then release server processors with 'Golden Cove' cores.
It's certainly not worth 'getting a stiffy for' another 8 CPU cores that perform like lower clocked 10th generation Intel cores.
If they can squeeze out a bit more power efficiency, I'd have thought another 2/4 performance focused cores would impress reviewers and customers much more. Or just a large boost to L3 cache instead of E-cores.
I could be wrong, maybe Intel are only thinking about competing in multi-core performance.
If there's anything new released in 2022, perhaps it will share some features of Sapphire Rapids server CPUs.
We know Sapphire Rapids server CPUs will use 'Golden Cove' Cores like Alder Lake, so is Intel likely to put more advanced CPU cores in 'Raptor Lake' CPUs, released around the same time? I find it doubtful.
The server CPUs are scheduled to launch for Q2 2022, according to this article:
https://www.anandtech.com/show/1679...-2022-q1-for-production-q2-for-ramp-h1-launch
EDIT - couldn't Raptor Lake just be a HEDT counterpart to Alder Lake CPUs, rather than mainstream desktop parts? That would imply quad channel memory support, and presumably higher L3 cache and higher core count for some models.
A HEDT series would allow them to charge about £1000 or more for the top model in the series, if the 'Cascade Lake-X' series is anything to go by. That would presumably be a model with 8-16 more cores than the 12900X and with more L3 cache.
If they could even release 'Raptor Lake' as a new desktop series on LGA1700, that would prevent them from selling a HEDT series for higher prices, since the core count would likely be the same.
The interesting bit, if they might be able to forgo the 'E-cores' entirely, in favour of all 'Golden Cove' cores. Power saving cores on a HEDT series would be a bit silly
As far as I can tell, Sapphire Rapids server CPUs have entirely Golden Cove cores...
Games don't need more than 8 performance cores and that will be the case until consoles get more than 8 cores - so just adding efficiency cores for multithreaded performance makes sense
