syphon it ? and run some water+detergent through, I used a long handled brush for painting radiators to give mine, that had some mold, a scrub/cleanSo I suppose the plan should be to drain it somehow and try to flush it out? Car is an F01 730d. Is it easy to drain it? Any thoughts appreciated...
the other renown problem is fluids mixing and gunking up the jets, so run some water through.
are the brake lines going to be an mot issue - 3 series touring I had both runs replaced at an indy, they had to drop fuel tank I think, so was ~£300I'm not greatly mechanically minded, would anyone mind telling me how inflated these prices are (appreciate some of the issues aren't explained that much, this is from BMW)...
diff was weeping a small bit - but I checked & topped it up.
boot struts oem stabilus brand I got from germany about £40/pair 4 years ago
