Caporegime
- 30 Jul 2013
Got to the open world and performance tanks with 3080ti + 5800x. Anyone got optimised settings?
Digital Foundry did a video on it
Can anyone tell me how I can rid my PC of this pop up. Clicking cancel usually means the games will load just fine but not all.
Obviously this is Halo but it happens on most other games it seems. I have Googled without success so hopefully someone here can help.
Its my personal gaming rig.Is your pc controlled by a network administrator? This happens when the file what is required is located on another computer.
Yeah got that but I am looking for a way to resolve this.For what ever the reason the file its looking for it's not located in the correct location.
Will do but I do feel this is a bigger problem than just Halo as I mentioned it happens quite often with several games. Unfortunately I do not have much installed at the moment but I can remember a couple of demos recently just would not launch because of this issue, one was Chorus if memory serves.OK try browse to the halo install location and then you want to look inside a folder with additional files.
Sorry not at the pc right now with correct names of the folders provided by games.
Yes I do I have a separate SSD for my games.Do you install your games onto another drive other than C:?
Because that software from Microsoft is looking for it within C: drive you need to point it to the correct folder for the games.
So where should I be looking on the games SSD?
Followed this to find the folder and ProgramData is missing?If you open that folder it's looking for is they anything inside it? C:\ProgramData\Package Cache\
What Is the ProgramData Folder in Windows? (howtogeek.com)
Found the folder just not where it was supposed to be.Right for some reason you have lost that folder. It looks like a lot of files that games use to install the software come from these folders.
How to get that back I am not sure. You might need to create the folders yourself and put in the software its asking for vc_runtimeadditional_x86.msi 14.28.29334
You will need to download this file from Microsoft or maybe a system restore point can help.
