Replaced spark plugs,
Replaced front brake pads and flushed front and back brake fluid
Is it bad that I only realised cars have 2 pads per caliper when I saw them on the inside of my Caterham's front wheels?
So ashamed...
TBF you'd say a set of pads as they come in pairs/4s/8sIs it bad that I only realised cars have 2 pads per caliper when I saw them on the inside of my Caterham's front wheels?
So ashamed...
Pair of shoes in a drum tooIs it bad that I only realised cars have 2 pads per caliper when I saw them on the inside of my Caterham's front wheels?
So ashamed...
You’d think so... I mean how else would it grip?Pair of shoes in a drum too
Unsure on handbrake calipers but presumably two as well.
Aye, but I thought one for each sideTBF you'd say a set of pads as they come in pairs/4s/8s
So ashamed...
So ashamed...
check with Nasher if this is ok, he’s the expert on EVERYTHING car related.
Heh, thanks. But thinking about it logically, how would it be able to clamp down on the disc down if there was only 1 pad?Don't worry, I have a friend that was a go kart racing driver, now has a track car and is trying to become a racing driver and didn't know either.
Actually he doesn't know anything about car mechanics, but he is a really good driver.
Now I'm helping him with his car and he is learning
Had an altercation with a muntjac in the wife's car on the way to work yesterday morning.
Thankfully all it broke was the lower grill, chrome skid plate, and smashed the number plate; the bumper popped back in and amazingly didn't break any clips.
First time I've actually hit one, had several close calls in the past, but this bugger darted out from a verge on the left side, not even sure I hit the brakes before hitting it at 60. Lucky it wasn't worse to be honest, they can make a right mess...
They're a bloody menace! My route to work is littered with them this year it seems...It’s telling that I got this far through your post before checking your location to confirm you were somewhere in Norfolk![]()
Garage took car on for suspension noise.
They found 15 bolts that were not tight. 2 were loose.
All done up to torque spec...
Last time I use a young mobile mechanic lad to install suspension parts.
