Is that actually true, though?AMD is apparently unhappy with the preferential treatment TSMC has given to Apple and it's affecting the pace at which AMD can develop and launch new products
What products do AMD have right now that require TSMC 5nm and are held up by Apple?
What products do AMD have coming that require TSMC 3nm and will be held up by Apple?
Now granted we're not on the inside, but there's always been a pattern than Apple uses TSMC's bleeding-edge node with AMD mass-producing on the node behind. Apple's new silicon moves to the next bleeding-edge node, AMD then takes Apple's place.
Sure, 7nm production was very cramped and it's if AMD were ever unhappy with sharing the 7nm pie with Apple it'd be then, but that's a one-off, isn't it? When AMD move to 5nm production Apple will have moved to 3nm (or 4nm if the rumours are true about 3nm being delayed).
And from a layperson's perspective, TSMC has many different nodes in the 7nm family, maybe AMD should've designed all of their stuff to use all the nodes, rather than get bottlenecked with 1 of them
If anybody is annoyed by TSMC's preferential treatment it'd be Qualcomm.
I wonder if the scalpers are scrambling to their posts ?
