- 3 Oct 2012
Upgraded but had to roll back to W10 as my headset's mic would not work. No workarounds would work, but going back to W10 fixed it immediately.
Have to disagree with the above. I have not found anything which does not work the same apart from one program which is getting an update soon. Even that is not a deal breaker as it still works but gives some minor graphical glitches.
Hi Few questions
I'm thinking of doing a fresh install of windows on my pc to give me a fresh start,
1. is it worth upgrading to Windows 11 yet or should I wait a few more months and stick with windows 10 ?
2. PC check has passed everything but my CPU is not supported for some reason. https://prnt.sc/25h2ctf
i can still install it using a workaround but is it worth it
3. Will I have an issue with drivers?
Thanks, I was wondering what to do and was about to reinstall windows 10.1: I'd say go for it, save upgrading at a later date.
2: Mine was all fine apart from CPU but it still installed fine and I didn't use a workaround, just d/l the iso, used that and no issues . If that doesn't work for you and you do need to use the workaround it works fine, I got it running on a core2duo at one point. Just use rufus it has an option to install with no checks.
3: Drivers should be fine, I've not had any issues at all with drivers on a Ryzen laptop.
Hi Few questions
Thanks, I switched to windows 11 over the weekend after updating the bios to the latest one and it worked great, I was expecting to have issues considering everything MS said, it was the fastest windows install and setup I have ever done.Yeh, go for it, on Win 11 here and no problems at all (so far, touch wood).
Also will have to amend my earlier comment about extra key presses (referring to right click menus), I missed the new icons at the top for cut/paste/copy.
You have until 2025. You can use Microsoft's tool, it's not bloaty. Alternatively, the WhyNotWin11 tool does the same thing but better - https://github.com/rcmaehl/WhyNotWin11/I had a system message stating my PC is not up to scratch for Windows 11 but when I clicked to find out more it wanted me to download some tool to check. All seemed odd to me and I don't like installing loads of bloatware so didn't bother.
I think I have a few years before I need to really concern myself with an upgrade.
This is another little thing in windows 11 that bugging the crap out of meAlso is there anyway of getting rid of more options for things like copy and paste.
I think you can change this ive seen a few youtubers show you how, search for windows 11 tips on youtube or google.This is another little thing in windows 11 that bugging the crap out of me
