Looks like the 42" C2 is confirmed but it and the 48" C2 will not be using the brighter panel. I don't think it is an issue myself as my 55CX is plenty bright and a 42" would make way more sense on my desk![]()
I read the 42 and 48 won't be getting the new panels somewhere this morning.
I really want a good 48 TV this year for ps5 and movies. Screen burn still puts me off, have to see if anyone does a QD at this size.
There is a big difference you just have to do your home work like me, I'm sure if you google it imo OLED are more sharper image, 100% colour fidelity 4/8k, so when watching/playing in Dolby vision or HDR you can get the best out of your TV I compare this with my old LCD 4K HDR TV, if you play games in HDR 100% oled light it's going to be very bright compare with LCD + HDR because of the independent lit 8.3 million pixels of OLED, LCD use a background light to display the image not the same as you know, of cause you can lower the OLED light in games also on the TV but if you lower it too much you lose the HDR effect I only play SD games so I don't care and watch Dolby vision with Netflix & Disney plus. The screen size is a debated topicYou said you don't want to sit too close to an OLED like a LCD. So what's the difference between OLED and LCD at same size screen that creates the issue is all I am asking. Simples.
Just an FYI that link is only valid for TV’s. The author or staff member says as much in the comments.There is a big difference you just have to do your home work like me, I'm sure if you google it OLED vs LCD. OLED are more sharper image, best colours in 4/8k, so when watching/playing in Dolby vision or HDR you can get the best out of your TV, If you play games in HDR %100 oled light it's going to be very bright compare with LCD + HDR because of the independent lit 9.2 million pixels of OLED, LCD use a background light to display the image not the same as you know, of cause you can lower the OLED light in games also on the TV but if you lower it too much you lose the HDR effect I only play SD games and watch Dolby vision with Netflix & Disney plus. The screen size is a debated topic
If you want to sit closer to an OLED @42/48/55inch your going to turning your head a lot there is a distance calculator but if you feel it wrong that your choice![]()
Unfortunately, as I previously mentioned, our TV size-distance calculator isn’t really designed for monitors (or TVs as monitors) so I really can’t say what the idea distance would be in your case. As always, the general rule is that you don’t want to be too close and end up straining your neck because you have to constantly tilt or move your head to see different parts of the screen and the work you’re doing. The issue is that this can vary between users, so it’s one of those things where you’ll have to experiment and see what a good range is for you!
I didn't read the comments, my mistake so just use a TV guide for exsample at the timeJust an FYI that link is only valid for TV’s. The author or staff member says as much in the comments.
Yeah, I sit much much closer to my monitor than what that guide recommends. Been like this for decades. I sit around 30-40cm away from my eyes to my 27” monitor. So I am thinking adding another 20-30cm to that I will be fine. But each to their own. Some sit around 4 foot away from their small monitors for example, to me that is missing out on all the extra PPI. Might as well not bother with 4K at that point.I didn't read the comments, my mistake so just use a TV guide for exsample at the time
Here is a TV/monitor
https://stari.co/tv-monitor-viewing-distance-calculator
I wear distance glasses so I sit far back from my 55CX the PPI is 82 but because it a bigger screen on the desk I change text in windows from normal 300% to 150Based on reports for CX and C1 I am not seeing many burn in issues. The percentage is very small. Happy to take the risk as it is by far the best image quality one can get. Normal monitors just don't compare.You will know more at CES show January 5, 2022 what's coming soon.I wear distance glasses so I sit far back from my 55CX the PPI is 82 but because it a bigger screen on the desk I change text in windows from normal 300% to 150
4K is very nice but you need the hardware to run it my system is old so I am wait for the cards to drop in price, OLEDs also have problems with static in games/work monitor some people get burn-in some don't it a panel lottery debated topic but when you spend over 1k for TV you want it to last a few years not change it every year unless you got the extra money to spend.
That's because of the anti burn-in features in the C9/CX/C1Based on reports for CX and C1 I am not seeing many burn in issues. The percentage is very small.
Why 2 years? Just wait until end of the year and get a 4080 that will no doubt be better. You waited this long...I'm waiting for the RTX 3090 TI to come out the price might be £2300. but are willing to buy one not going to wait another two years for the 4090
So are you guys going to buy the 42inch LG C2 WOLED or 34 inch Samsung QD-OLED?
No chance. 42” LG all the way.Hopefully TNA will get both!!
Then tell us which one is best to game on.
