You beat me to itThe new OLEDs will have 48gbps HDMI 2.1 now, A9 gen5 and will be brighter too on the C2, 42inch
Does it finally have a gigabit ethernet port though?
Don't blame the engineers you fiend, blame the industry! Entire TV industry is generally stuck in its ways based on decades-old models. Annual release cycles, leading to short support periods, etc.No, since all TV engineers believe 100Mbps is enough for all streaming platforms and services and they have never heard of 4K UHD, high bitrate, AppleTV or an dictionary.
100Mbps was introduced in 1995, 1000 Gigabit Ethernet came out in 1999, and still in the 21st century OLED TV industry can't go behind 100! Just run it though your PC it will have a Gbps Lan chip so you can run 4K Netflix/Disney plus without been capped.Does it finally have a gigabit ethernet port though?
Yes but it's **** all to do with OLEDs or LG... I'm pretty sure every TV available only has 100Mbps.100Mbps was introduced in 1995, 1000 Gigabit Ethernet came out in 1999, and still in the 21st century OLED TV industry can't go behind 100!
Yes all TVs is stuck in a 1995 era and LG OLEDs supposed to be the modern superior TV in 21st century but struck in era too.Yes but it's **** all to do with OLEDs or LG... I'm pretty sure every TV available only has 100Mbps.
FTFYYes all TVs is stuck in a 1995 era and LG OLEDssupposed tobethe modern superiorTVin 21st century butstruck in eratoo.
It also works as a double meaningFTFY![]()
:O I didn't know about that meaning!It also works as a double meaningSo I can't have an opinion
LG updated to 04.30.58 Fixing minor bugs in software. did you get it!The latest update for the C1 did something weird. I keep getting those eye strain warnings for high brightness settings.
I'm in Gaming Mode with OLED set to 25.
Just checked because I never know these versions. Mine's 3.21.20 and didn't find an update through the UI.LG updated to 04.30.58 Fixing minor bugs in software. did you get it!
Or buy Cable Matters USB to Ethernet Adapter (USB 3.0 to Ethernet) Supporting 10/100/1000 Mbps Ethernet Network, for the TV
