Still testing and trying to find an ideal daily overclock for this 12600kf, I've gone from a simple
All core 52/E Cores 41 @1.36v to
Per core 54/54/53/53/52/52
E Cores 42
Cache 42
1.38v
There's just so many settings left in the Asus Bios that I have no idea about so more research is needed.
Next up is Ram, currently using Corsair LPX 3600 c18, but I've little to no experience in overclocking and tuning ram, any advice would be greatly appreciated![]()
Are you seeing any particular advantage in moving from a fixed all core overclock to the type noted above..?
And has anything changed.?
Thanks
I'm sure another BIOS update or two will sort that 4000 kit![]()
@FlyingFish perhaps you do not need 1.3v for your vcore under load.? Not much difference I know but mine seems to need 1.284v for a 5.1 and 4Ghz overclock. I use a 420mm AF AIO.
They can soon get toasty tho, perhaps more so when running Cinebench. But that's only for testing and not typical use.
ell today I got another response from them stating that my memory is on their approved list and should work fine.
Problem you have with RAM from vendors like Corsair is they will up revision the RAM when the change something, and usually that is the actual RAM IC's. Have you confirmed what revision or ver number is on your RAM vs what Gigabyte have tested on their board locally?
What other RAM have you tested at the same speed and capacity to check that your IMC can do what you are asking of it?
Yeah, I realise Cinebench stresses a cpu like nothing I would ever do in real life, its still useful to make sure my cpu isn't going to get fried though if something does decide to push the cpu. And peace of mind for stability
Can I ask how are you setting the core voltage?
I've just been doing all my testing/adjustments with Intel's XTU program, and just ran a negative offset on the core V.
I have Corsair Vengeance 3200, working. And 3600, using. The 4000Mhz ones should default to 2133 when I have reset the CMOS.
I assume you have tested just one module in the correct slot and then swapped to the other to test them individually?
When you reset the CMOS with the other RAM what is the default voltage applied by the board?
@Journey Many thanks for your suggestion to try just one stick......................
Ha, donkeys years of trouble shooting 10000's of systems and parts and sometimes I'd even miss the obvious. Glad you've figured it out for now.
Decision fine RMA them, or wait?
