Greta Thunberg
Permabanned
2 Sep 2017
Because there's no data or because we don't report it?
There is a global warming, it is accelerating and things become worse by the day.
There is no data for "cold records broken", but even if there could be one or two cases, they wouldn't influence the global picture.
30 Nov 2005
The data needs to be visible if 400 stations record highs, how many if any are reporting historical lows?
Transparency is key
30 Nov 2005
No data? Your 100% sure? Or just not interested in balance.
Slovenia beats the all-time national record with below -20 °C this morning. Numerous nearly 100 years old records broken with extreme cold across Europe
By: AuthorMarko Korosec
Posted onPublished: 07/04/2021
CategoriesEurope Weather
Below are some of the most impressive and record-breaking values this morning:
-19.8 °C – Babno Polje (the previous record was -19.0 °C set on the April 4th, 1970)
-19.5 °C – Zadlog
-14.6 °C – Iskrba pri Kočevju
-13.1 °C – Marinča vas
-13.0 °C – Kočevje (the previous record was -10.5 °C set on the Apr 14th, 1986)
-11.6 °C – Dobliče pri Črnomlju (previos record was -5.5 °C set in 1955 and 1956)
. [, the weather station Nova vas na Blokah hit -20.6 °C and set the new official lowest temperature for April (the previous record at the station Nova vas was -18.0 °C set on April 4th, 1970)
weather station in the village Retje near Loški Potok.
The previous official record for Slovenia was held by station Pokljuka (elevation approx 1350 m ASL), with -20.4 °C set back on Apr 9th, 1956.
Cherry picking data is not science, we need to see all data..
https://www.google.com/amp/s/thehil...ld-reading-for-northern-hemisphere-set-in?amp
13 May 2003
So as you build more wind turbbines and solar they MUST be paid to generate or not generate if and when they are available. It's the market rules. So you now have more generation that is actually useful sitting around not making money when wind and solar are generating. But when as regulalry happens they don't or it is insufficient to meet demand the reliable fossil plant needs to turn on.
-So we are paying for under utilisation of fossil plant in capacity market payments effectively.
-We are paying for the increased breakdowns caused by extremely agressive running regimes.. on, off, on, off, on, off you get the idea.
-We are also paying for risk. Eye watering risk. If next week your CCGT fell over over it would cost you £500k a day minimum to buy back the electricity you were committed to producing. If the temps are a bit cold and the wind below 50% of rated capacity that's going to be more like £4million a day. 10 years ago £1000 per MWh prices were considered price gouging and oil station were getting told off for offering them. This winter, several times a month for back to back days the spot price has reached in excess of £1000 per MWh.
Gas prices have shot up but that is only part of the story our electricity generation is approaching breaking point. Dungeoness and Hunterston AGR's will be gone soon. Sutton Bridge, Baglan Bay and Severn Power have been shut for several years. The last coalers are going over the next 18 months. The reliable portion of UK generation is it's smallest ever. That comes with costs.
Permabanned
2 Sep 2017
False positive.
That is a fake data. Because of climate change, there are cold spells of weather in isolated regions.
It is like the cold air from Siberia moved over Europe and stayed in there for a while till it mixed with the warmer air masses from the Atlantic ocean.
Meanwhile, the reality:
“You can certainly see the effect of climate change in our weather in Kenya, and globally. We’re just putting together the data for 2021, but we think we will have seen an annual temperature which is 2.1C higher than normal for some parts of the country. The shifts are very noticeable, from one extreme to another in a very short space of time.”
Heat records broken all around the world in 2021, says climatologist (msn.com)
30 Nov 2005
False positive.
Your a naive fool. Good bye.
30 Nov 2005
I don't know if trolling is still allowed. I guess it is... :rolleyes:
A different opinion is not trolling, grow up
https://www.google.com/amp/s/amp.cn...ord-cold-antarctica-climate-change/index.html
Antarctica's last 6 months were the coldest on record
By Allison Chinchar, CNN Meteorologist
Updated 12:30 PM EDT, Sat October 09, 2021
(CNN)In a year of extreme heat, Antarctica's last six months were the coldest on record.
"For the polar darkness period, from April through September, the average temperature was -60.9 degrees Celsius (-77.6 degrees Fahrenheit), a record for those months," the National Snow and Ice Data Center (NSIDC) said.
Permabanned
2 Sep 2017
A different opinion
A different opinion that states some observations but doesn't try to explain them, right? :D
Storm-Steering Jet Stream Could Shift Poleward in 40 Years - Scientific American
"The North Atlantic jet stream, a fast-moving air current circling the Northern Hemisphere, may migrate northward in the coming decades if strong global warming continues.
The consequences could be dramatic: shifts in rainfall patterns across the midlatitudes and an increase in droughts, heat waves, floods and other extreme weather events in Europe and the eastern U.S.
A new study finds that the jet stream could shift outside the bounds of its historic range within just a few decades — by the year 2060 or so — under a strong warming scenario. The findings were published last week in the journal Proceedings of the National Academy of Sciences."
Weakening jet stream causes the normal westerlies wind blowing over Europe to change direction and start blowing easterlies. Which means cold air from Russia has a higher chance to sit over Western Europe.
30 Nov 2005
Not my area of expertise, I just want to see all data not just data showing one side.
Balance.
What do you think will happen to northern Europe when the guild stream drops down?
The Sahara desert was under water 15,000 years ago. Where do you think the gulf stream was positioned then? What did. The UK look like 11,500 or so years ago?
Caporegime
22 Nov 2005
I watched a docu that said the stream is moving regardless of global warming seemed pretty convincing...
if the poles flip they will blame global warming too, if the moon pulls stronger on the tides, global warming.
just the leap to answer for all our problems these days
30 Apr 2006
London
100% agree, some climate change is happening, but it's nowhere near is bad as the doom merchants are saying it is. But what is clear that for the last 10 years all sorts of companies have used it as an excuse to squeeze more money out of the general public, from supermarkets charging us for plastic bags to energy companies rising prices to eye-watering levels. It's obvious and frankly disgusting
