Man of Honour
Still waiting to see if they are releasing the 3070T 16GB. I mean not sure if I should get a 3080 now, some folk are saying 10GB ain’t enough?
Will prob end up being hard to get newer cards than current ones and its already a big hassle.Still waiting to see if they are releasing the 3070T 16GB. I mean not sure if I should get a 3080 now, some folk are saying 10GB ain’t enough?
Not me, as long as it works I am going to just leave it the hell alone lolAnyone is planning of undervolting their 3080/3080Ti?
You not heard about theeasy riderTNA shuffle then?
crushing fear of everything getting in the way again?
im heading straight of an under-volt, if it’s quiet enough, overclock!
Nervous nelly about tweaking with things this expensive and hard to get.
Where is easy btw? Haven't seen him, loadsa, or Gregster in ages!
DRAMA!easy made his own thread about owning the 3060Ti two years.. greg was put off by @TNA violence!
Did you nuke the GPU driver when you switched from AMD to nvidia? Does sound like you could have conflicting settings on how your controlling the fps.
My general understanding is you find out the real range of your monitor from the manuf. spec, if the games supports it lock the range to within that spec. Gsync/Freesync should do a good job as long as its applied, but you can add other software settings that may counter it. For example on the AMD side if you ran Chill which adjusts your fps by trying to save power, it could be doing the wild fluctuations of fps between your 150 to max.
Your best off capping with in game framerate setting or RTSS as using Vsync will add more input lag.I have, when I installed both cards, it was on fresh Windows installs. The games run perfectly up to 180 fps, anything above that is awful, so I have to either cap it with software or turn VSync on.
So I received mine early today. It has replaced a 6800XT and so far I'm noticing a marginal performance increase in Warzone, Rise of The Tomb Raider and Halo. Immediately did the undervolt to 850mV at 1800 and it sits around 62-65 degrees in games.
I'm still having my ongoing issue of anything above the refresh rate of the monitor (27GP850-B 180Hz) becomes choppy/stuttery. It's not screen tearing, it feels more like really low fps even though it can be sat at 220-230 fps. So my issue must lie elsewhere. Not sure if it's my understanding of Gsync/Freesync/VRR that is the problem (most likely) but from my limited understanding, if the screen does 180Hz and my game is sat at 220-230 fps, it should be butter smooth correct?
Could a motherboard be a cause of my problems? It's a MSI Tomahawk MAG Wifi with a 5800X.
