Permabanned
- 28 Sep 2018
@Vimes gear 1 is much more important for performance than command rate 1 vs 2.
@Kelt - have you checked your vcore voltage when it is running cinebench R23...? Not what you have dialled in, but actually running at when at full load overclock. The reason I ask is that when I had the MSI 690 Pro I needed to use adaptive voltage with a negative offset, or it would scale up quite high with just a manual vcore setting. I noted your Cinebench R23 screenshot in that other thread, and you are not far off thermal throttling, at 95c.
Just noting what you have written about entering 1.26v for your vcore.
@Kelt well done
When I had the MSI 690 Pro board, very impressive, I noted that the lowest vcore I could go to when running R23 would be fine and perfectly stable.
But I started to have some doubts when playing a game that used much less CPU overall load it would rarely exit to the desktop. So I raised the vcore slightly.
I noted that the vcore when under full load, and obviously at the 5.1 and 4Ghz, would then be at a lower vcore in a game that might be using the same Mhz speed but not full load.
I suppose that might be one factor as to why some people see great stability at full load but a potential problem at a much lesser load.
There can be other factors as well.
mine seems to do 44 locked.
Glad to hear they are being responsive, just be wary of they get you to send one only back they you want the same version returned.
Your return merchandise authorization (RMA) has been approved, and we have included a return label as an attachment to this message. Please carefully follow the instructions below to ensure a smooth return. Note that if a Corsair agent has given different return instructions specific to your situation, those instructions should be followed instead.
All modules of memory kits being returned, even if not all are faulty. Due to compatibility concerns, we do NOT replace partial kits. Failure to return all modules will result in your replacement being delayed until we receive the missing modules
just got an RMA acceptance from Corsair. They include this in their instructions....
seems good so far. Kinda impressed, rang them, they are based in America and the place of shipping the sticks to is the Bolton shop.
@Kelt you can see from your screen the very low wattage that it is drawing, very different from the 200w+ when running R23.
Is that with a fixed 1.25v vcore that does not change with the CPU speed and not an adaptive one which will vary..?
you did mention that you set a manual vcore.
I've just sent a 12900k back and grabbed a 12700k because the temps on the 12900k was really bad. I've gone from 70-90c during gaming / benching to a nice 40-60c on the 12700k. All in all im very happy with it.
All I've done so far is to set the core voltage manually to 1.26V, and the core multiplier to 51-P and 40-E.
Voila, rock solid 5.1/4 Ghz, with nice, cool and silent running.
