Permabanned
- 14 Dec 2011
Well said SilverRST!
We can never have to many sizes - options!
But what kind of OLED? JOLED or from their own OLED?LGs long rumoured 31" OLED probably will come out 2023, LG milk that OLED cow like nothing.
And indeed, patents holds back innovations big time.
They weren't talking about the current OLED monitors which are JOLED? I'd welcome the 32C3 tbh if LG's OLED because they look much better than JOLED. JOLED are absurdly expensive it won't get any better and it's been since the first announcement from 2018. We'll see if 32C3 will actually happen next year. For now, 42".I don't think anything was said in the rumours, perhaps their own LG panels cut from the same mother glass units from the larger OLED screens like 83".
I was pretty certain of buying this (well when it has its first sale as want it under £1000) as a PC monitor, but knowing it doesn't seem to feature the EVO panel/tech of the higher C2 range is disappointing. Think anything QD-OLED is just going to be mental pricing for the first gen and doubt I can keep waiting...
ps3ud0![]()
Yeah you are probably right, just made it more wait and see rather than must-buy for myself especially with the Sony XR-42A90K existing...I'm not sure it's that important, the peak brightness of the non-EVO panel is pretty solid compared to most PC monitors out there, and you're sat up close so don't really need retina searing brightness.
ps3ud0![]()
I just found a neat website with the measurements in metrics (cm) and also to see the 42" in detail:
https://lgvirtualstudio-he.com/ces/tvs?category=OLED&product=C2
Yeah, this design comes totally unexpected to me and I was worried about the back too, also because of the VESA holes. The 48" for example has inconvenient VESA position and the 42" has them like any LCD TV has which is a good thing. And indeed, look at the back of the 42C2, OLED tvs are supposed to be very thin but this one is fat so it should have a heatsink. But I'm not surprised because the C1 stays the most popular.Nice spotting, 42" OLED has Evo mentioned in its specs. The lower end panels A2 and B2 don't mention Evo panels and have the slower cpu.
I like how LG designers put all the hdmi ports on the side, much more easier then trying to fumble around from the back or underneath looking at sony
designers here. The 42" is pretty much exact same size as my 43" LED TV so should be a direct swap size wise for me which is perfect.
I'm pretty sure too. The OLED EX is supposed to be 30% brighter and I don't think that's a good thing to use as a monitor. Anyway, even "low-end" OLED is miles better than any LED LCD.Appreciate the links, I'm sure they'll eventually confirm the specs - I just get the impression that Evo and OLED.EX are 2 different things and not meant to be interchanged - not 100% sure if the 42"/48" have both.
ps3ud0![]()
No, if you want a 27inch oled you can buy the 27EP950-B, but it capped @60hz if want 120hz you have to buy the 48/42 OLED versionYeah, we should all just want/need the same thing, right?
