Where is that from?![]()
Pcore/Ecore setup. Zen4 should take the lead over RPL and then lose it to MTL.
This is AMD's real plan for Zen4, Metal IHS lid with new even faster ants inside.It will be defective or just a blank with the IHS over it so no worries on that
Hmm. So no mention of Threadripper then? Shame, I'd love to see an upgrade on that part.
Where was the price shown up in the slides? As for all we know AMD may charge £500+ for this if it's the halo gaming CPU.So in a few months the best gaming processor you can buy will cost only £400. Not bad in that respect at all.
Zen 4 looks tasty doesn't it. I wonder how many cores we will be looking at for the top spec chip?
Yeah its annoying that TRX40 is seemingly a dead end product.
Threadripper are high margin, i'm sure if they had the capacity they would...
I think AMD is using its TSMC capacity where it’s needed most. The demand for home systems and servers has probably taken priority. With Zen 4 being close to release and DDR5 the Zen 3 Threadripper have probably fell victim to the pandemic.
not as high margin as epyc though and that fact is the key
Not sure that is true except in maybe a few corner cases. It's typically 5950X > 5900X > 5800X > 5600X. Highest clocking parts + most L3 cache win overall.
I know you are trolling, but the post I was quoting was specifically about AMD parts.Correction: i5 12th gen Alder Lake (or greater) > 5950X > 5900X > 5800X > 5600X in gaming
Also the same for energy efficiency when gaming. I know you mentioned how you're planning on running your 5950X at eco modes to save power, it would workout cheaper for you to upgrade to a 12th gen CPU, as these are so efficient in gaming![]()
The 5800X was frequently better than the 5900X in gaming, though.
As always, we get very little from the show and tell and reviews will show us what we need to know.
