Don
- 20 Oct 2002
- In a house
Ok, enough guys. Let's keep this civil, and on topic....
I'm really not. Lol... ambivalent, perhaps, while also somewhat entertained by your contradiction, but certainly not angry... Lol....
No, you're dismissing those that don't gushingly affirm what you've already decided.
You don't appear to even know what my actual opinion is...
Wrong.Your opinion isn’t advising me to get a KitchenAid.
Right?
Nope.You think I should ignore those 100 people saying KitchenAid are reliable and good and only listen to you and you only.
Right?
Have you read any objective reviews, assessments, product test or similar, that merely present the product as is and thus allow you to make up your own mind?I picked a small selection from other forums but each one of these comments are weighted equally, together with yours.
And you keep on procrastinating... Just buy the ******* thing, or don't. You've already decided you want one, and if yours happens to fail or simply does not meet your expectations, no amount of statistical opinion profiling is going to make any difference to your personal experience.I know, he keep on swearing! Lol
Wrong.
Up to this point I've not actually advised you either way. I'm letting you know what alternatives are "cheaper and better", which is exactly what you asked for...
Nope.
I do think you should consider why some people still chose other models when the KA is reputedly the god of stand mixers, while giving the gushing fanboy comments the same subjectivity weighting as those 'user error' complaints - People who drop a lot of money on top end kit will often understate, trivialise or even ignore niggles, problems and the like... I forget the actual term for it, but it's somewhere between commitment bias and the sunk cost fallacy.
The fact that you're asking people to talk you out of buying one suggests that you already know it's not worth that amount of money to you.
not at all - stand mixer identity politics is rife.Another thread ruined by ttaskmaster
That's right, *I* did not choose a KitchenAid... but that does not mean I think you should do the same.If you are CHOOSE something else NOT KitchenAid then you are NOT choosing KitchenAid?
Depends... do you actually want someone to talk you out of the KA, or are you just looking for validation?I know there are other options, if you think they are Cheaper And Better then you think I should get them?
That seems to be what you want to hear... but I'm not interested in any responsibility for what should be your decision.Unless you think I should get the more EXPENSIVE and WORSE KitchenAid?
You assume user error... based on what, I don't know, but presumably your aforementioned model recommendation in the user manual which isn't actually there?To put someone who has one working for 30 years and on the same level with people who dismiss it due to user error or small niggles seems VERY fair to me. In reality I should ignore those with negative due to user error but i am not.
So basically both conditions would cancel each other out and leave you back where you started.....I also know that when something is wrong, more people will come out to say it, there is an actual term for that too. Vs when someone is just happy using it, those people don't make any noise, because when something works, you forget its existence as it just works.
I would suggest reading a few more comparison articles, preferably by people who use them in some kind of professional capacity - You'll get a good spread of opinions, plus a load more anecdotal 'heresay' from other users in their respective comments sections.I also watched a couple of direct comparison.
Well, a lot of people do buy KitchenAid purely for the looks... especially the 'Candy Apple Red', it seems.If I were to get it on looks alone I will be honest with you i am getting the KitchenAid, everytime.
Aside from the several already in this thread... Is your Google-Fu that bad, or have your parents locked down your internet?I am not procrastinating, I am researching, I am waiting for that flood of negative reviews for KitchenAid to appear or the flood of Kenwood fans to turn up![]()
As usual, I merely voiced an opinion which got met by someone who didn't want to take it as given and chose to debate it instead... If you don't like it, you can always use the Ignore button.Another thread ruined by ttaskmaster![]()
In that case, I do think you should buy a KitchenAid... I suggest ignoring any advice on models or performance and just buy whichever colour you like best. That seems to be the level you're working to, here.Believe it or not, no matter how many words you write, it has the exact same weight as someone who says “Kenwood”.
To be fair @Raymond Lin you asked for people to talk you out of buying one and not for people to talk you into buying one![]()
10/10 for effort.
Ah, but are all of them the right model for the product you want to mix, ie Artisan for bread... or is every vote counted equally, regardless of relevance of circumstances?a real dilemma V
