How's this for coil whine?
How bad is this in others' opinions? The noise isn't being picked up that well, IRL it's about that loud with the case closed.
Welcome to 3090 FE models... they all do that and some much worse than yours, we had some at work that would sound like a hive of bees in the room and then some that sounded like high piched scraping a chalkboard. Thats why we returned some and sold the rest that we tried to fix with new pads and hot glue on the chokes but made no difference.
Some start out loud and get a bit better and some just got louder and some well decided not enough noise so started to have fans that would make noises too from the bearing or rubbing against the cooler.. We had over 22 of them and all gone now because they drove us crazy even after we exchanged some of them, they would come back with new issues, if it whined before now the fan rattles and screams or fan rattle we got a whining card. We returned the ones we could for AIB blower cards or 3 fan AIBS in the end to save our sanity in the office.. Imagine 2 x 3090 in each machine doing that as all our workstations are 2 x 3090 in NVLINK or RTX Titan cards in NVLINK. The RTX Titans when we got them we never had this issue with them.
3080 FE and 3080Ti have it too.. It's some sort of design issue or the cards really hate high FPS, it's a lottery with them, that's why I stayed well clear when I got my own 2 x 3090s for my workstation at home, mine don't make any of them noises and you have to put your ear right up to them to hear electrical sounds but the 3090 FE still is the best looking 3090
. Not sure why the FE cards are worst for it as I have a 3060ti FE and that dosn't coil whine, something with the GA102 chips power design and clearly something now up with the 3090Ti too as they told AIBs to stop production till they fix some issues with the cards.. guessing power related..https://www.techradar.com/uk/news/r...-bios-and-hardware-snags-and-thats-fine-by-us
hopefully the replacement is something with a better level of coil whine that a game can drown out.
Actually the Suprim doesnt really have coil whine either but its in my garage so i cant hear it anyway.
