When my eyes fail me; How do i know DLDSR is working?
Once you enable it in the control panel, you'll see the new resolutions in the game. When you select those resolutions, it means it's on.
I think it only works in fullscreen mode.
Screenshots generally get taken before the downscaling takes place so just see the game's render at the higher resolution. I expect that makes a lot of comparisons out there a bit moot. I read that GFE screenshots should be updated to take them properly but my screenshot hotkey seems to stop working after I run a DLDSR resolution, curious if it working for others and just a problem with my own system?
For example I start Guardians of the Galaxy, press hotkey works fine, change in game resolution to 2880p and no longer works. Alt-F2 photo mode stll works but end up with full 2880p shots anyway. Lowering resolution back down again and the standard capture hotkey still doesnt work...
Tech Focus: Nvidia DLDSR - What Does AI Downsampling Actually Do?
Can you get 8K to work?Been messing around with this more especially in games with dlss, this is a killer feature to have, works so well. Recommend people give this a shot in cyberpunk.
Any game really. Not tried it yet myself. You have a 4K OLED don’t you?For cyberpunk? Only tried it on my 3440x1440 display so res. are:
5160x2160
4587x1920
Both work fine but 5160x2160 (and arguably so is 4587x1920) is too much even when using dlss performance. Probably could get it running well tbf but then I would have to sacrifice RT psycho settings and some of the my mods so wouldn't be worth it imo.
Any game really. Not tried it yet myself. You have a 4K OLED don’t you?![]()
Will install something like Prey and try it on that soon.I do, some games I play more on monitor though as sitting at desk with m+k just works/play nicer I find.
