- 30 Sep 2005
Ultrawide is all set up, going to order the 27"s for the weekend
Wouldn't mind seeing it for ideas once its all set up![]()
Considering going for the Samsung G9 and binning off the VR all together.
Currently using the GTOmega Apex stand and it's solid with the 8nm CSL DD.Hi, are there any rigs that can be used from the comfort of your sofa?
What a weekend!!! Things not going easy that's for sure.
Getting there slowly though. Waiting for some parts to come today to get it all finished.
Doesn't look quite right from the position I was in when taking the photo, but when sat down it's pretty damn epic!
Looks great!
I have the G9 and toyed with the idea of side monitors when I get a bit more room. Would you mind saying what PC you have powering it and what frames your getting?
It’s a nice setup you have there @TheOracle , I’ve not seen triples run with a larger middle monitor before. Would you be able to post an image of a GT cockpit so I could see what sort of view it gives you?
Thanks for that @TheOracle, higher than I thought.
The video looks spot on, really showcases the view.
Do you happen to have ACC to try?
