I came in here expecting to see the sky falling after the igor's lab socket thing. I guess people don't think it's a big deal assuming your temps are decent?
Yeah, sorry. I'm behind the curve.Are you talking about the article from way back in December? It's most likely because it isn't a common issue. I've not seen any Alderlake owners on here mention it.
Yeah. I'd only just heard about it. Seemed like a lot of fuss at the time but seems to be pretty much a non-issue.What was that about?
Was it the washer "fix" to get lesser temps, or summat else?
There are a couple of videos further up, however, if you just want stock clockspeeds then I would start with a -0.050 offset on the vcore. If that works, keep pushing it until you see a performance drop off or instability.
10-15c difference for me when gaming compared to leaving it at auto voltage + better performance with the cores boosting .2ghz higher.
Hi. Can I do this on the MSI boards?
What was that about? I'm using a £25 air cooler on a 12700kf and it maxs at 80 degrees in Cinebench multi. Not seeing a temp issue here!
Yes, I have this option on my MSI board.
Look in the voltage settings for CPU core voltage mode and set this to Adaptive + Offset
Then change the setting below called CPU Core Voltage Offset Mode to '-'
then below that change the CPU Core Voltage Offset to a value you wish (0.050 seems to be a good starting point. I have mine at 0.125)
12900K purely for gaming? Yes you would be wasting your money. 12700 is where it's at, but 12600 is more than capable.
- Checksum: 5C1C
- CPU VRM parameter calibration for improved performance
- Fix system reset Thunderbolt issue
