Found the place last night by accident. It is near the main terminal. Tried out the different gamma settings and sure as **** it makes a HUGE difference.
I took two screenshots. On both settings are the exact same which is using DLSS Performance, so I could make it look better if I just turned off DLSS or went DLSS Quality, but wanted to just show what I am seeing. One is the gamma setting I use myself and the other is turning it way up to illustrate how it can have an impact on IQ.
https://i.~ibb.co~/Vvh40jg/1.jpg
https://i.~ibb.co~/YhjfFtV/2.jpg
Time of day and angle of picture I found makes a big difference to the image also. This was a quick screen grab I did not spend ages on. But now that I know the place I can take more shots another time if there is demand for it
Oh and I noticed Shanks has a different FOV also which would have a small impact on the way it looks.
What do you guys think, from what I can see my image quality looks better personally.
TNA the debunker!
So just up gamma and get RT quality folks
But in all seriousness, much improved, however, how does it look in other areas? As generally changing things like gamma, brightness, contrast can work great for "certain" scenes but look awful in other areas, it's why I don't like any redux/sweetfx presets now.
I got to the center last night and it is definitely rather different to the first area! This area is a lot more demanding than the first area too (cpu usage has gone up a fair bit too I think?), at least on my end and also a few frame spikes in this area compared to first, still very playable on the whole though. As you can tell, my paragliding skills aren't quite there yet
Combat is improving somewhat in terms of variety now that I have got more weapon mods, throwables, skills, different weapons although the bow I got is pitiful! Literally pointless using the standard arrows unless when upgraded they do a lot more damage.....
