- 11 Jan 2007
- *̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
Is there no charger with this? Accessories seem to indicate a cable only. Seems a bit tight if so with a 1200 quid phone.
have you managed to order one using above ? is that any Samsung store ?
So far though I am struggling to find an reviews on the UK model with exynos 2200.
Is this what an upgrade with the upgrade program should look like? I entered my details, chose which one I wanted, told it my current S21 is fine and got this. Seems like a new order to me?
found the offer. This maybe the best offer for me as I have a s21+ 256gb to trade in and purchasing the ultra 256gb in store with my amex and the total remaining would be £569 , will see what my local Samsung store provides tomorrow and post back
https://www.hotukdeals.com/deals/sa...ck-up-to-ps250-american-express-amex-3885814?
Can anyone confirm if the s22 ultra is a dual sim or single sim from sammy direct?
They said this with S21 Ultra then it turned up and took 2 physical SIMs anyway lolIt's Hybrid sim so can use 1x eSim and 1x normal SIM.
Always surprises me how many people seem to buy things without reviews being out firstI believe there's still review embargoes.
Always surprises me how many people seem to buy things without reviews being out first![]()
Most are only pre ordering so if you don't like you cancel, waiting for the actual release means you miss out on the promotional add ons
Also DSR comes into effect on most purchases.
Correct, I've pre-ordered on the basis that I can cancel if its a dog of a handset. Tbf though it would have to be really really bad because I've been generally ok with 21U Exynos, I just miss the s-pen a lot and prefer the sharper, simpler look.
