Yes, engineered.you mean its engineered ?
as they are all 10s
There's a number of mods that can be applied - only one at a time though.
"Fast scan" at its highest grade - 5 - cuts scan time down to 2s.
as they are all 10s
One character with its assetts per account, but your can switch between modes as you like.I've not looked into the wing stuff. I thought you played in solo so how does that work?
OK, so he's gone into open play, gotcha.
Since I was doing cargo anyway, and I could afford, I just put my asp explorer in storage, bought a type 9, and filled it to the brim with cargo bays. I can carry 720 cargo now instead of 60. But it will take me 10 jumps instead of 2 to get back to Alcor. So I'm not sure it's actually that more efficient. Plus I just had an interdiction attempt on me and only just evaded it with this lumbering thing.
So I might just sell this thing again when I arrive.![]()
not quite
im in a private session with another player
communications panel > players > add to wing
then in the mission panel at the docking station, look for the blue symbol bottom left of the images of the missions, those are wing missions
if it says 5 million, you BOTH get 5 million
well worth doing !
sounds interesting these Thargoid vessels.
Well,ifwhen i get killed
While we talk about game modes, it's worth adding only in solo mode one can take a high resolution screenshot. Default shortcut alt+F10 iirc.not quite
One is to fight Thargoid scouts, but honestly I'm not sure you're properly equipped for that yet, in terms of your ship, weapons and (probably) your progress on engineering. By all means give it a go, but you might want to leave any expensive modules behind to minimise your rebuy costs![]()
