If i go to get a key meter load up a years worth gas/ele before april will i avoid the price increase if i do not put any money in april ?
Yes and no.
Yes doing this could avoid the rate increase.
No b cause no provider will install a key based meter only smart Pay as you go.
i get that not using the key for a year so the pricing on the meter doesnt update is a strategy but wouldnt it be the case when you top up eventually the key will backdate the pricing and everything will be recalculated on the suppliers side once they have the consumption data?
