- 13 Jun 2012
running fine for me in the last 20+ hours.cheers.
different agesa and file size from the beta, so not just an 'approved' re-release of the beta.
aye bt odd, the version number actually went backwards for it also
beta was v183, release is v180
either way it 'upgrade' from the beta, and seems to be grand
It's just MSI's naming/numbering convention - first two numbers are major version, third number is 0 if release version or goes up in sequence with beta versions.
I think I just left mine off the default setting, which may be balanced... If you look at the fan curves you can see it doesn't come on until the chipset gets to a certain temperature (can't remember what it was, 60 let's say), then ramps up very rapidly to max speed only about 10 or so degrees hotter than that. You can customise the chipset fan curves manually if you like.what is the optimal setting for the chipset fan-- silence, balance or boost?...at what temps do the fans start up in the various modes?
Mine's on default and I have never seen it ramp up during use. It does spin for the boot up sequence but that's normal, after a couple of seconds it stops.
I have heard it's only if you fill the second m.2 slot which is chipset controlled and do a lot of file transfers, that's when it starts spinning.
Core performance boost should be on by default and just makes the CPU boost above base clocks, if you had a 5800X for example and turn off core performance boost the CPU would sit a 3.8ghz and not boost any higher.what's the difference between Core Performance Boost vs Precision Boost Overdrive?...PBO seems like the auto-overclocking setting but then what does Core Performance Boost do?...should I have it enabled?
Auto is indeed enabled as it's the stock setting for the CPUs and is basically the setting for boost clocks.in the BIOS 'Core Performance Boost' is set to Auto...the only other option is 'Disabled'...so I'm assuming Auto= Enabled?
I *think* you might be able to disable the m2 slot/s in the bios, but I'm not 100%... if not, could you not just manually change your boot preferences each time you need to change OS?I'm new to NVMe drives so forgive the newbie question...after an NVMe drive is installed is there any way for me to disable it without physically removing the drive?...I want the ability to boot into another SATA SSD drive independently...meaning I want to install another copy of Windows 10 onto the SATA drive and use that...is there a setting in the BIOS that disables the NVMe slot?...can I then re-enable it and get back the drive with everything installed on it intact?...I have an MSI X570 Tomahawk motherboard
with SATA SSD's (and older mechanical hard drives) it was easy to just unplug the SATA cable and plug it into a new drive
