You know that snapped in half blue switch? I did a thing...
Broken bga chip that you can't identify to buy a replacement, all I know is its some sort of stepdown IC.
Got me a template and you can't see it but that chip is under the cam in this pic and is the same dimensions as max17050.. its tiny...
cleaned up the chip thin layer of flux (too much in this pic)
solder paste in the stensil.
Re-balled my first bga!
This is where it needs to go. So I cleaned that up...
Put my chip back on and it pulled into place like a champ
That took me probably 10 attempts of failing to reball that chip but man it was satisfying when all the little balls finally worked!
Now I had to do all this because that switch was bad this is the one that was snapped in half. So far we have replaced a fuse, 4 caps, a shorted cap on m92 that was the cap and not m92?! the cap behind the fuse was also shorted, shorting 15v to ground so that was also replaced. Finally after that and a new port I was able to get the switch to accept a charger but problem... I found that we have a short on the vsys rail... with vsys being the main rail on a switch that short could be anywhere, so I did what you should, set up voltage injection into vsys. With that done i set the bench supply at 1.5v and let it rip. The board ate 2amps quite happily so I had a feel around and this cap bottom left of the image burnt me. removed it and the short went... so thats cap 5
For anyone interested that IC to the right of my broken cap is for the audio.
As soon as I removed that cap my vsys short was gone, I havent fully fixed this one yet but It's coming along nicely
just got to put a port back on it, put m92 and bq back on and give it a test. I'm not going to lie I think this one is possibly going to work now. Ill probably stick it in a pink or a grey case we shall see whats here once we have it booting.
And yes im switching between projects all the time so that I don't lose patience and burn myself out on one single thing.
