- 11 Dec 2002
- Darkest Norfolk
Agreed. Bean to cup via user![]()
that covers all coffee - starts as a bean, ends up in a cup
you have set up a mortgage £4.5 each .. if we had a deep fryer they'd be my downfall though.
hardware - read today breville (the real Aussie Sage company - I've lost track ?) bought Lelit
https://themarketherald.com.au/brev...an-specialty-coffee-company-lelit-2022-03-11/
Yer - bit of a shame that, hope is the run it separately but don't honestly believe they won't start money saving![]()
Think my Sage Barista Express might be done for. Turns on, heats up and the grinder works but it will no longer pump water through the machine. Just get a loud click and nothing.
Had a couple of appliances pop in Storm Arwen in December when a power cable got damaged. The power grid engineer who came out warned us that other appliances might go over the next 12 months as some damage isn't immediately noticeable.
Sounds like it's time to treat yourself to an upgrade![]()
descale yesterday 2 packs of cafetto restore , rather than cheaper citric acid , it gives less blue residue so must be worth it . I'll mix it myself next timemy HX machine (tap water) needs doing - the flow rate seems to typically drop off and a shot takes longer, pucks looser :
my theory is that the OPV valve may become less efficient with scale, although that is on the cold side of machine, so maybe its fur in the grouphead.
Our organic range contains only ingredients that are sustainably sourced and free from Genetically Modified Organisms and phosphates. All products are biodegradable and certified for use in organic systems, which means that if you’re using organic coffee beans and milk, you’re fulfilling an end-to-end organic experience for your customers. Our organic range of products contains ingredients that are either plant derived or naturally occurring:
Chemical Name EC No CAS No weight-% Classification accordingto Regulation (EC) No. 1272/2008 [CLP] REACH Reg. No
Citric Acid 201-069-1 77-92-9 >60% Eye Irrit. 2 (H319) 01-2119457026-
Tartaric acid 201-766-0 87-69-4 1-10% Eye Dam. 1 (H318) no data available
Found a video on YouTube with someone who had the same issue. Ordered a new water pump on Amazon for ~£20, came the next day and took 20 minutes to replace.Conclusion is, maybe this replacement pump was not as well made as the original one, which was marked made in Italy;
although it was 'only' £14, may contact seller I don't expect to renew a pump anually. - or ? counterfeit pump
My Sage BE arrived and it's in near immaculate condition. No scratches, dents or damage anywhere on the machine. The odd bit of dried coffee, but nothing else. It also came in the original box with all accessories apart from the water filter (the holder was included however).
I ordered some beans from Square Mile which should hopefully arrive this week. I also sorted some other bits from Amazon which arrive today - small digital scale, Sage knock box and a filter.
Any advice on dailing in the machine? I watched a couple of videos on YouTube, but it would be great to hear advice from actual users in here.
