I had a damaged box but fortunately inside the box there is adequate padding and protection so you should be ok.Yes, the damaged boxes are concerning me.
Are those the only two things on your packing slip?
Mine shows this:
For my full price order, yup.
Second discounted order shows the same items you have.
None for me either
I don't think i would worry about it, unless they are putting the cable in the box at the warehouse before hand.
Mine semed like it was sealed from factory.
No movement for me either, yet. Also, I've seen on reddit bunch of posts by US customers of Dell, where Dell canceled quite a few orders that had discounts applied to them, for this monitor - after a while of these being stuck in state of "Confirmed" and some even in "Production", citing pricing error. But not all of them - many were sent out. It all seems to depend on how Dell feels like doing case by case, it would seem. Hopefully this will go through, but it did make me worried a bit.
What is the price of this monitor? If I can get a hold of this monitor I might sell my 27Gp950 on
1099 without discounts, but most of us have used various codes to get it down to 850 - 900 range.
Such a good price even at 1099
What are the discounts?
Apparently problem with most of these codes is that they're targeted at specific companies/partners of Dell and weren't supposed to be used by general public. Which is why Dell cancelled a bunch of such orders in US (as per Reddit). Same with leaked Premier direct links. Though, a lot were sent out with these codes without issues (as even shown here), so fingers crossed it will be fine. I reckon it depends on how many people "abused" this system - if it's a handful only, they likely won't care to cancel and risk bad PR. But if it's a really large number, then Dell might decide to just cut it off at some point and cancel the rest.
In either case, it's their own fault for letting anyone just enter any discount code without warning about "This code is only for this or that organisation" - not really customer's fault.
Why on Dells site does it sayI wouldn't be surprised if that is why some people are seeing their orders take longer even though they got them in at the same time as i did.
Mine was a legitimate NHS Blue light discount code. You have to request a code through a special app to get them.
It’s not my on packing order slip. The uk plug that is. I never have much luck. This is on the back of three faulty Samsung neo g9. Is someone gonna start a best settings thread?
