OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
Hi guys,
I've put up some info regarding the 2 new 4K monitors from Samsung.
The listings aren't fully complete but should have all the info you need to determine if these are for you.
No images anywhere yet of the G75 so just reused the G85 images. The only difference i believe is that the back shell is grey and not white.
This should be dropping in Q2 but its very possible it could slip into Q3!
Check them out below!
Samsung 32" Odyssey LS32BG850NUXXU 3840x2160 VA 240Hz 1ms FreeSync/G-Sync HDR2000 Curved Gaming Moni @ £1,298.99 inc VAT
Display Resolution 3840x2160, Display Size 32", Refresh Rate 240Hz, FreeSync, G-Sync Compatible, 1ms Response Time, Contrast Ratio 1000000:1, Panel Type VA, USB 3.0, Curved, HDMI 2.1, HDR 2000
Only £1,298.99 inc VAT.
ORDER NOW
Samsung 32" Odyssey LS32BG750NUXXU 3840x2160 VA 165Hz 1ms Freesync/G-Sync HDR2000 Curved Gaming Moni @ £1,098.95 inc VAT
Display Resolution 3840x2160, Display Size 32", Refresh Rate 165Hz, FreeSync, G-Sync Compatible, 1ms Response Time, Contrast Ratio 1000000:1, Panel Type VA, USB 3.0, Curved, HDMI 2.1, HDR 2000
Only £1,098.95 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
