@NikTheSHNIK any update on when these may be touching down in the UK fella?
No sorry, still just getting mid to late July.@NikTheSHNIK any update on when these may be touching down in the UK fella?
What spec PC are you testing it with out of curiosity?Damn this monitor is sweet. BTW there are scan-lines at 240 Hz.
10-bit color works at 240 Hz.
None of my DP cables would work, I had to use the short thick DP cable included. Going to have to buy a fiber optic DP cable looks like.
The testing continues!
I suspected that this would be the case, pushing that tech hard!Damn this monitor is sweet. BTW there are scan-lines at 240 Hz.
Dude buys every top-end screen going, at least 5/6 times a year. Use your imaginationWhat spec PC are you testing it with out of curiosity?
So this thing has MBR (strobing) at both refresh rates (120/240). Not very good though, I just stick to VRR.
Also, this is the first curved monitor I've had that has "wings". I mean, the center is curved but then the ends/sides straighten out flat as a pancake for about 4-5 inches. Pretty distracting. Screws with your brain not seeing a constant curve. Looks like like a butterfly affect.
What are your thoughts on the monitor so far?
Wait until you go back to a flat screen it will look really odd like it's bending backwards well it did for me anywayAlso, this is the first curved monitor I've had
Thanks for that, nice and concise review that tells us 99% of what we want to knowJust a quick summary of pro's and con's for the monitor in my testing:
