What was wrong with yours.?Replacement arrived and perfect. Asked them to check replacement as no point sending out another dud and must say this is spot on.
Wow that was quick!
I just saw this exact thing on a thread on AVForum, user had a couple of those bright spots. Said they ran the pixel refresher and they were gone.
Pixel refresher sorted it out so happy days. Looks like I will be keeping this one as it’s the best out of the three uniformity wise.
Might be that I'm not used to OLED, but I found OLED 80 which is the default was best for me, can't say I've seen it wash out any details but I'm also in a fairly well lit room.
Sure.How about a pic of the uniformity after the refresh.
Absolutely can’t fault them one bit and they were very apologetic when swapping TVs as if it was their fault lol. Hopefully yours will be fine and won’t have to go through what I have.Awesome glad to hear. Hoping I don't have as many duds when mine comes this weekend, can't imagine mr lewis being as fast and cooperative about returns/trying multiple models. But fingers crossed.
@R3X I'd seen that video and was basing my settings of that but found that OLED 25/55 was to dark, I also changed the aspect ratio from 16:9 to Original which is missed in that particular video. I also found a page on the LG website where they recommend using OLED 80 specifically, but can't find it now, I'll add a link when I do.
When I saw that bright spot on the third one that got me properly ****** off but luckily ended up not being too much of an issue.
Here is my cx, I would call this acceptable tint.
this is the only recommend using OLED 80 specifically by LG
https://www.lg.com/us/support/help-...lg-4k-or-4k-oled-tv-CT10000018-20150577528034
Colour uniformity.What was wrong with yours.?
Cheers for that link, yeah I too have gone from phils video but I also checked Vincents own one and hes almost the same but takes down the sharpness to 0
from 10. I think like Phil and vincents video suggest 80 oled light is not good for SDR, 25 is apparently the right one or was for the C1 series it gives 100nitts. Think the C1 defaults @ 25 oled light also for SDR.
If memorys correct 4K HDR and DV OLED light defaults to 100
could be wrong on the above though, I know in the past many recommended just set to filmmaker mode and leave it all on defaults (SDR,HD SR,DV) and just adjust the oled light to something your eyes enjoy, but I find details missing in blacks so need to increase Black level to 60-70 even, this could be why some just suggested use your own settings since we all prefer different things as in no ones right or wrong.
That’s how my third one is which is horrible for desktop usage.Colour uniformity.
Seems some people have been able to get hands on with the Sony version, abit briefly: https://www.t3.com/news/ive-seen-sony-and-lgs-42-inch-oled-tvs-and-here-are-their-highs-and-lows
Seems it can get brighter, abit just one opinion and glance of the tv. I expect being master series and cherry picked if I recall with that series will be the better panel wise, more so if they get gaming features up to snuff, abit at a price I expect.
I have 30 for SDR gaming I just don't want to wear sunglasses for HDR gaming
HD doesn't have much to do with HDR.Yeah 30 sounds good for SDR.
I was playing around a bit more with settings, I was getting confused with HD and HDR content. So its SD, HD, HDR and then Dolby Vision content I need to find and then fine tune and apply for all hdmi sources.
I think I am ending up with a hybrid of Phils and Vincents and my own settings at this point.
What is your black levels? I found 50 default was no good for me on HD and HDR so tried 57 to fix it but need to check this bit more.
